Question about diconnecting fuel lines when dropping the engine
This is probably a stupid question, but to anyone who has dropped the engine from a 993, how much gasoline comes out of the fuel lines when you disconnect them? I am in the process of dropping the engine in my 993 and I am at the point of disconnecting the fuel lines. I attempted to loosen the fuel line for the return portion of the fuel circuit and am finding that there is quite a lot of fuel draining out, I have half a plastic water bottle that I used to catch the fuel and I've filled it probably about 4 times and the rate at which the fuel is draining doesn't seem to be slowing down. Is this normal or am I missing something? Should I have drained the tank before I started to drop the engine?
GC
GC
I had no problem just disconnect at the fuel filter, You are probably siphoning the fuel. Is the car level? Is the tank full? My tank was half full just a few ounces of fuel.drained off and I used a bung in the filter outlet.
My tank is probably a little over 3/4 full. I suspect you're right that I am siphoning fuel. I will try your suggestion of disconnecting the fuel filter and capping that off. Thanks.
GC
GC
