Suspension Setup Choice
#78
I reached out to Hergesheimer MotorSports asking about caster, kt, and main spring explanation and they have not responded back.
i saw mark initially for 2min and he left
its interesting but when i went to pick my car up they really didn’t speak to me, i paid and a porter pulled the car up, they main guy Mark was mia.
i wasn’t a fan of the ride hieght and the office manager stated “that was what the tech found to be good”
not a good experience....
#79
If you want your car set up right, take it down to San Diego and have Jae Lee at Mirage International do it.
Jae is meticulous about his work and understands the 993 suspension with its KT, etc. and has done final set up for my cars for years.
A great guy.
http://www.mirageintl.com/
A great guy.
#80
A great guy.
A great guy.
interesting... your the 2nd person who has told me this... I’m going to have to check him out
#81
I would go back to them and get them to provide a KT measurement on the document. On my alignment I saw them do it but the tech forgot to write it down since it is not a standard measurement on their template. Went back to them and it was a 15 minute exercise assuming they did the KT setup.
#83
@dutchny they will hang the kt tool on your rear brake caliper bolts while the suspension is loaded which gives a KT "number" and basically is the caster value. Needs to be equal on both sides...and within a range of values which I can't remember of the top of my head. May be in that table @billv shared earlier. I know it's in the Porsche repair shop manual for the suspension values.
#84
I didnt understand how I told them to get my ride height below RS specs and KT was confusing.
Currently getting Tramont wheels refinished, and while its up in the air, Installing new RS Side Skirts and Tore HID / RetroFit Projectors.
#85
#86
Spoke to Jae at Mirage, KT adjustment is done by hand by him, with the wheel going up and down upto 2" to stimulate braking and acceleration, he measures it and adjusts.
#87
That's a bump sweep, he is measuring toe change over suspension travel, Idea is a vertical line, worst is a horizontal line, neither will never happen, the best you can hope for is as close to linear and vertical as you can get
#88
Interesting. Is this a legit method to set KT for lowered cars using either stock or monoball control arms? Seems elegant, but actually really difficult since to measure in compression, you'd have to remove the spring or find some safe way to compress it. Measuring in droop would only get you half the needed data.
#89
Generally it's sufficient to measure the caster w/ the Motorsports Gauge but that depends on having a stock motorsports suspension setup. Of course most of us do except for the big variable of static ride height.
#90
Removing the spring is the method Mirage does it.
