993 Forum 1995-1998
Suspension Setup Choice
Old 12-18-2018, 07:04 AM
  #31
GBX
GBX's Avatar
Originally Posted by DutchNy
What do you guys recommend for coilovers?
Currently have Pss9’s, should i upgrade to kw v3’s?
i love my KW V3s. Great dampening options. SS bodies. Always found PSSs to be harsh. If I were to do it again, I’d also consider Ohlin’s R&T
Old 12-18-2018, 09:53 AM
  #32
uniquenamehere
uniquenamehere's Avatar
Are these available for the 993?
Old 12-18-2018, 10:53 AM
  #33
craina
craina's Avatar
Yes but last time I checked no US based distributor carried them so you need to go through a British distributor.
Old 12-20-2018, 07:18 PM
  #34
DutchNy
DutchNy's Avatar
KW’s arrived today
Old 12-21-2018, 11:55 AM
  #35
Cupcar
Cupcar's Avatar
Personally I made my own sub frame bushings and I like the idea of raising the sub-frame relative to the chassis since this, like the RS uprights in the front, lowers ride height but helps to preserve design roll axis of the chassis.
Old 12-22-2018, 11:51 AM
  #36
DutchNy
DutchNy's Avatar
How did you make your own?
Pics?
Old 12-22-2018, 01:07 PM
  #37
Cupcar
Cupcar's Avatar
I noted that threaded bolt receivers in the chassis were very slightly out of square which is probably a non-issue, but it bugged me. It's no problem with the rubber mounts which allow for it easily, but I didn't like bending the bolt a bit. You can see in the photo with the arrows the slight offset.
So I sketched up a design using stainless spherical washers that allow for some motion and had a friend make them with his CNC machine.
The design also allows me to tilt the subframe with spacers if I want, but I didn't like the idea of less anti-squat geometry.
Old 12-24-2018, 01:45 AM
  #38
DutchNy
DutchNy's Avatar
Ended up also adding the Tarret Toe Link also.
started degreasing 20+ years of grime
Old 12-24-2018, 02:54 AM
  #39
Tripp993
Tripp993's Avatar
I tried the H&R Bars and they were too stiff. My car came with TRG 25mm front and 23mm rear and have to run lower spring rates than others with the RS bars. I may change to RS myself.
Old 12-24-2018, 10:28 AM
  #40
DutchNy
DutchNy's Avatar
I have been reading that. I may just run the stock bars until I source the RS bars.
Old 12-24-2018, 10:45 AM
  #41
DutchNy
DutchNy's Avatar
Ordered Elephant RS Uprights also
This suspension refresh has become costly lol
Old 12-24-2018, 11:35 AM
  #42
Tripp993
Tripp993's Avatar
How much are you driving on the track? I may consider selling my TRG bars if I buy the RS bars. I think the good thing about having the RS bars is that seems to be what most people run and when doing setup, spring rates will be recommended by others based on the RS bars. I just did a new suspension set up also and I've done 4 track days of testing and have been through 2 sets of springs.
Yes, mine too!!!
Old 12-24-2018, 12:37 PM
  #43
DutchNy
DutchNy's Avatar
Couple times a year on the track. The car is for Canyon Carving...
Old 12-24-2018, 12:55 PM
  #44
Tripp993
Tripp993's Avatar
I will probably buy the RS bars and test at the track and if I like them I'll be selling the TRG's. I've already made my car 10 seconds faster over the past year at Barbers and I'm trying to get all of the time out of it. Driving on the road you will not notice a difference in any of the three bars (H&R, TRG, RS) and on the track you may notice .5 sec differece depending on setup with slicks. I've had all 3 bars but didn't change my suspension setup until now. Either way I will have one set of bars for sale if you are interested.
Old 12-25-2018, 10:00 PM
  #45
DutchNy
DutchNy's Avatar
Started on the rear this afternoon, took awhile partly me trying to figure things out but it came together nicely.
Rennline and KW quality is great. Ira from Tarret Engineering was very helpful and a wealth of knowledge, highly recommend him.
Still need to figure out this ARB and Drop link situation but will finish the other side first.
Waiting for Elephants RS Uprights for the fronts.
Quick Reply: Suspension Setup Choice
