Sunroof delete project help. - Page 3 - Rennlist - Porsche Discussion Forums
Old 12-12-2018, 07:26 PM
  #31
Spyerx
Spyerx's Avatar
You guys can check my build thread. Why? Weight clearance and looks.
Remove glass
remove headliner
remove sunroof mechanicals
cut our non needed bits
hand formed panel. No filler needed. Beautiful job
paint top and interior
dynamat onnroof
new custom headliner
replacenglass.
Spyerx is offline
Old 12-12-2018, 07:33 PM
  #32
Endoman
Endoman's Avatar
Originally Posted by Bill Verburg View Post
Here's a 993 roof w/ the internal structure visible
When I did mine I replaced the whole roof and finished it w/ Perlon, what you depends on how finished you want it.
The delta is 54#, the biggest benefit is headroom when wearing a helmet
That's exactley how mine was done. Could even be mine it's the same colour. Beautiful job looks completely original. Be advised that going to a 993 roof will require a 993 front screen if you use the complete roof with scuttle.
Endoman is offline
Old 12-13-2018, 12:55 PM
  #33
DutchNy
User
Would love to do the sunroof delete with an see thru plastic so I still get the airy feeling in the cabin. Havent found any see thru material.
DutchNy is offline
Old 12-13-2018, 01:08 PM
  #34
MarinS4
MarinS4's Avatar
Originally Posted by samurai_k View Post
I have not seen the work yet in person, but there is a classic car restoration shop in San Carlos, CA that just did a sunroof delete on a 911. No filler... I have no idea if this is good work or not, but here are some pics of the delete.
There certainly is body filler on that one! That's far from paint perfect. Looks pretty good though.
MarinS4 is offline
Old 12-13-2018, 01:11 PM
  #35
MarinS4
MarinS4's Avatar
Now this is the right way to do it! Spot welds on the window frames and side seams in the gutter. Bill do you have underside pics of the sunroof delete version? I was not sure if the roof panel included internal structure. Based on your pics they do. Maybe enough to push me over the edge.
MarinS4 is offline
Old 12-13-2018, 07:26 PM
  #36
ilko
Agent Orange
ilko's Avatar
No need to get a whole new roof skin unless the car has some serious rust issues. And I wouldn't use the existing sunroof panel and weld around it. The gaps are too big to just weld your way to seal them. The Fenn Lane panel is perfect, but you need a shop that knows what they're doing to install it. It has to be seam welded but carefully because the roof skin and panel are thin, putting too much heat will warp the metal. When properly done the result is spectacular.
ilko is offline
Old 12-13-2018, 08:51 PM
  #37
Sirenty
Sirenty's Avatar
Does anyone know a shop in the Mid Atlantic area or NE that could handle this and do it well? And also potentially a 964 WB conversion?
Iím looking to do both and would like it done right the first time.
Sirenty is offline
Old 12-13-2018, 10:23 PM
  #38
Achtung964
Achtung964's Avatar
Any recommendations for a shop in SoCal?
Achtung964 is offline
Old 12-14-2018, 04:27 PM
  #39
911Jetta
911Jetta's Avatar
Contact RL's Cobalt, he's recently been through a WB conversion (check his threads for comments). He'll also know the best shops in the region.
911Jetta is online now
Old 12-14-2018, 05:48 PM
  #40
Brig993
Pino @ RSR Autobody Restoration in Wykoff, NJ. I was very close to using him. Pino is a great guy and his work is the finest.
Robert @ Finaltouch Collision in West New York, NJ. I got a few referrals from RL members who had their car refinished by them. I ended up using them after visiting the shop.
Another shop which I was referred to by Ilko (they did his RS) was Knight Time Autoworks / ERodTECH Rides in Argyle, NY. I spoke to them but it was too far away for me.
I spoke to/got quotes from all three of these shops.
Brig993 is offline
Old 12-15-2018, 12:02 PM
  #41
Sirenty
Sirenty's Avatar
Thanks!
Sirenty is offline
Old 12-15-2018, 01:02 PM
  #42
gmorat
gmorat's Avatar
Everything I need for my project (so far) has arrived and now it's just up to when the bodyshop can take the car.
gmorat is offline
Old 02-11-2019, 10:58 AM
  #43
Cowhorn
Cowhorn's Avatar
Can you give us a ballpark figure on those quotes? Thanks!
Cowhorn is offline
Old 02-11-2019, 11:05 AM
  #44
gmorat
gmorat's Avatar
They ranged from $15-25k.
The problem is the body shop has gone deep silent. I'm thinking of selling the car and not buying a black one at this stage which is a shame as the interior has been redone completely and the car is as strong as an ox.
Should have been half done by now.
G
gmorat is offline
Old 02-11-2019, 11:27 AM
  #45
Brig993
The sunroof delete as part of a full respray and overall cosmetic restoration quotes ranged from 15-30k. Much of the variation depended on a few things: your expectations and desired results, the overall condition of the vehicle (any rust, body repairs or prior accident damage to fix) and how far you want to go replacing parts; new glass, bumpers, trims, rubbers, seals, lights, fasteners, bolts, screws your adding significantly to the cost. This was in the NYC/NNJ area. Iím sure cost will vary around the country.
Brig993 is offline
Contact Us About Us Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
