Rear Wheel Bearing Install Help
in many cases the bearing has a magnetic side for a sensor, that magnetic side has the stamped letters.
the magnetic side would face in, towards the car.
our cars don't use the bearing surface as a sensor but to be consistent I've been pressing these in with the lettering facing the car.
if you learn the official installation orientation from ntn, *** or skf be sure to post it.
Thanks, I had no idea about the magnetic seals. Found a good video that explains things:
https://www.youtube.com/watch?v=8H6REkbEkuA
I've never checked the ntn bearings for the magnetic seal assuming since our cars don't use it, the seal would not be magnetic.
I have spare ntn bearings sitting here and the seals are magnetic!
