FS: 993 Fister Mufflers Stage 2
Darin, that's a very nice GTAW bead with no porosity especially right on top of what was probably a slightly contaminated GMAW bead from the factory. I usually have at least one or two less than tidy areas when I TIG over a previous weld line due to contamination in the older weld. I guess Lorenzoh is the one that doesn't have a clue about welding
As as anyone can see, the first pics posted look nothing like the ones FD posted. And I will agree, those last couple photos show some very, very nice beads.
I’ve used FD modded 993 mufflers in the past, amazing product and Darin is a good friend of mine. But the ones pictured here seem to have some Very substandard welding on almost every part that has been removed to get into the can, take a close look at the beads, sloppy does not even begin to describe them. Just pointing out a pretty glaring issue...
So Darin is your good friend, doesn’t seem like he has clue who you are in his post.
I have Fister mufflers on my 997 and they are high quality and sound great. Never cared what they looked like or to ceramic coat them . Saw the pics on Tarek’s Instagram and they look fine to me.
Tarek307 please post the pics here again, but be careful or Lorenzoh might call you an Anti Semite again if you disagree with him.
ps: I had fister mufflers on my first 911 ever a 2002 996, then on my previous 997S and on another 993, couldn't ask for better mufflers, i even had TUBI on another 997 that came with them & preferred the fisters to the expensive tubis.
