WTB RoW Turbo Front Bumper Cover
If somebody has one for sale that they are not using I would be interested. I need to buy one by next week and will go to Sunset unless I find a clean used one here.
Part# 993-505-311-02-G2X
Thanks for reading
Thanks for reading
These would be scarce used. Don’t forget to get a price from Gert at Carnewal in Belgium. First class service and Euro exchange rate may help you out. Lots of other bits and pieces needed I have an exhaustive list if you need it.
Mind sharing the list? I'm looking to replace my turbo bumper with ROW as well.
https://rennlist.com/forums/993-foru...r-on-a-nb.html
I’ll try and post the Word Doc here on Monday with all the parts and pieces. It’s pretty extensive and has all the fasteners and fittings on it.
My conversion was from the frog mouth C2 NB to Turbo ROW bumper so some parts may be overkill. It looks like some here already have the Turbo bumper just with bumperettes (NA)?
This is a list jhubs put together in 2008. Below is a thread that he started and chronos his installation.
https://rennlist.com/forums/993-foru...r-install.html
1 - 993 -505-311-02 Euro Turbo Front Bumper Cover - $1227.41
1 – 993-505-551-01 Ventilation Grille-$40.37
1-- 993-505-543-00 Bumper Trim Piping left-$38.48
1-- 993-505-544-00 Bumper Trim Piping right-$33.66
1 – 993-575-740-00 Sealing Wedge-$12.67
1 – 993-575-738-00 Sealing Wedge-$8.08
2 – 993-631-141-01 Vent Fitting- $3.84 ($1.92 ea.)
1 – 993-504-125-01 Wheel Housing Lining (driver side) - $96.15
1 – 993-504-126-01 Wheel Housing Lining (passenger side) - $96.15
1 – 993-505-793-01 Bumper Bracket - $6.57
1 – 993-505-794-01 Bumper Bracket - $6.57
1 – 999-911-398-40 Rubber Seal Roll - $18.83 (3 meters)
02 -993-616-521-01 Series Resistor for Oil Cooler & A/C Condenser Blower Fans- $109.22 ($54.61 ea.)
12 - 900-143-159-07 Tap screws for under the bumper and wheel liners - $2.18 each
12 - 900-143-113-07 Tap screws 4.2 for under the bumper and wheel liners - $0.51 each
12 - 999-591-850-01 Speed nuts for top of wheel housing liners – $0.35
02 - 900-187-103-02 Screws for Bumper Brackets - $.65 each
18 - 999-591-699-01 Speed nuts for liner support brackets and…etc. - $0.35 each
02 –900-143-087-00 Screws 4.8x - $0.67 each
rk-d (09-12-2020)
Great info! This list is a huge help. Thank you.
Curious why these would need to be included: "02 -993-616-521-01 Series Resistor for Oil Cooler & A/C Condenser Blower Fans- $109.22 ($54.61 ea.)"
Would the originals not fit for some reason? (I did not review the linked threads in detail yet - sorry if the explanation is provided there, and I just haven't got to it yet...)
Cheers~
Cheers~
^^ probably a 'while you are in there' addition
Correct. AC and fan resistors are very easy to access with bumper off. They are usually cracked and aged by now. I swapped mine out. One was cracked and one was fine. Kept the old good one as spare. I would also look to move the resistors from its original spot for easier access.
