Broken Litronic bulb socket
Hey folks, first post. So tried replacing my ds2 bulbs and cracked the bulb socket while trying to twist it on. I wasn't forcing it. The plastic just seemed to be brittle and broke off right at the groove that holds it in place.
The lights are working, but worried that eventually they'll wiggle off. Any ideas on a fix? Don't want to drop all the money on new igniters.
Any pics?
Here's a stock photo.The slot on the right side of red portion of the igniter socket broke off. Now the socket can just pull away from the bulb since it can't be twisted on as normal. Make more sense? I can take an actual pic if not...
I got you. Yes that is annoying.
Well, unfortunately other than trying to hold it it with tape or some other bodge job which I wouldn't recommend due to the heat- I don't think glue will work either as it's too small to get a proper grip.
So, you are faced with replacing the whole piece from Porsche, or you could look at the Bergville FX kit which is highly recommended and would update both your headlights current day standards at probably a lesser cost. It includes bulbs, ballast all wires and is plug and play. I installed mine just yesterday in 10 mins- Tore at Bergville makes great products .
Hope that helps.
Hope that helps.
If your original pods are OE Litronic I am not sure the bulb mounting layout is the same as the Halogen headlight pods the aftermarket conversion kits are designed to fit. If you post some pictures of the internals to your headlight pods members here on Rennlist can probably give more accurate advice and validate a good fit.
An aftermarket replacement may be the way to go. Bergville or eBay aftermarket kit. The Bergville kit is an easier and cleaner install and the eBay solution is a generic kit, the one with the slim ballast is the one you want. When I installed the eBay kit in my car the Bergville kit was not yet available, that was over 10 years ago and the eBay kit is working fine today, however, the wire leads to the bulbs was a lot longer than needed so they are tied up inside the headlight pod with the ballast so none of the parts are external to the pod.
Andy
Andy
Hope that helps.
Hope that helps.
Andy
Andy
Thanks for the references guys.
The original Litronic and halogen bulb holders are indeed different, and I would recommend to try to get a spare bulb holder. D2S bulb holders are available on eBay or elsewhere, and can be fitted to the existing wiring. Beware, this is a high voltage system, and any soldering or similar must be carefully insulated.
The Bergvill F/X T-LIGHT kit is made for use in the halogen version of the 993 headlight, and it would be a bit difficult to use it in a Litronics headlight . The Litronic electronics is split in two, with one unit in the trunk, and one inside the headlight bucket. There is no +12V feed to the low beam bulb in a Litronic headlight, and modifications to the wiring must be done to use our kit, as well as using a D2S bulb holder.
Cheers,
Tore
Cheers,
Tore
