993 Forum 1995-1998
help.water in footwell
Old 09-22-2018, 12:03 AM
JHR55
JHR55's Avatar
Default help.water in footwell
found back seat footwell bit damp. cant find source of leak. any suggestion where to check?
Old 09-22-2018, 01:36 AM
GC96
GC96's Avatar
A little bit more detail about your situation might be helpful to help us give you good suggestions, was this after driving in heavy rain, just sitting for some period in rainy conditions, or after washing the car? Have you checked the front floor panels for any water? Water can get into the front and travel back to the rear footwell. If you have sunroof you might want to check that the drain holes to make sure that they are clear and that the drain hoses in the rear are properly attached.
GC
Old 09-22-2018, 06:08 AM
Sire
Sire's Avatar
Do you have an sunroof, probely an tube for guiding water is broken or stuffed so the water cant go anywhere.
Old 09-22-2018, 09:05 AM
k722070
k722070's Avatar
lots of info from toga
https://rennlist.com/forums/993-foru...the-floor.html
Old 09-23-2018, 12:35 PM
gmorat
gmorat's Avatar
I had the same thing a while back and it was caused by an improperly fitted windshield from the when the PO had it replaced. I had it refitted and it stopped the leaking and more noticeably, the creaking.
G
Old 09-24-2018, 08:17 AM
JHR55
JHR55's Avatar
caught in heavy downpour couple days ago. no water in front. just right back seat footwell .
check the sunroof drainage. no apparent blockage.
need check under carraige
Old 09-24-2018, 11:01 AM
Endoman
Endoman's Avatar
I had the same problem. Changed the sunroof seals checked the drainage holes no joy. Water was running down the B-pillar rather than the drain. Temporary fix was Gaffer tape (very ugly). I eventually did a sunroof delete after water got in the immobiliser. Radical and expensive but happy now.
Old 09-24-2018, 11:03 AM
willus
willus's Avatar
I've been fighting a similar issue in another car. I think the issue was that one of the sunroof drains was partially blocked. It would drain water, but when I checked the other drains, they all drained water substantially faster. When it rained hard enough and that corner was the low corner, the partial blockage was enough to cause an overflow and interior flooding.
I tried sucking the block out with a vacuum (no luck), pushing through with a bit of flexible metal "rope" (no luck) and finally using an air compressor to blow air through (success?). The water now flows through that drain much more quickly and it's survived a few big rainstorms with no flooding.
Old 10-01-2018, 09:35 PM
JHR55
JHR55's Avatar
still cant trace leak. spray waterb on roof for 10 minutes. nothing.
spray under carraige. still nothing.
remember drive through puddles water during heavy down pour before i discover the water leak.
Old 10-01-2018, 11:33 PM
jfischet
jfischet's Avatar
i wonder if the water is getting flung off the rear wheel and somehow getting in from there.
Old 10-02-2018, 01:10 PM
993KHTO
993KHTO's Avatar
I recall a friend had driven on a very wet day as well. No water in front seat foot area as the water settled in the back seat foot well and under the front seats. Couldn't find the leak via spraying water all over the car. Ultimately found out water was entering around the front dash area where some wire harness lost some sort of rubber housing which made the wire harness water proof. After lifting the carpet they found the front seat foot area WAS damp. The water simply moved quickly to the back seat foot well where it settled. Hope this helps.
Quick Reply: help.water in footwell
