Slave Cylinder Dimensions
Does anyone know the slave cylinder bore diameter and stroke length? Or, if someone has an old garbage slave cylinder lying around, I'll buy it off you.
I have some old notes from a couple years ago saying bore size was 24mm... But I don't remember measuring so I'm not sure how much I trust that.
Thanks,
Justin
Thanks,
Justin
Why do you ask?
Should end up with a couple data points. Putting one in a buddy's 964 as well, and my math shows .825r/.75 front so I'll start there... I'll start another thread to document the process and share my spreadsheet.
