Engine problem
Engine problem
hi~~
Engine problem
1. Switch the R gear, the engine is like a deep breath of oxygen deficiency.
2. There have been articles before, the engine speed is 6000 rpm, the first gear is changed to the second gear, and the vehicle is driven to 6000 rpm and cannot enter the third gear.
Hope someone can help me.
Engine problem
What is R Gear?
What is "deep breath of oxygen deficiency"?
Others may know what you speak of, I can't follow.
Andy
Andy
I would first check the plastic parts of the shift linkage and also the engine and transmission mounts.
If it will shift into 3d with the car not moving or at low RPM it may be things related to the shift linkage moving around.
Easy inexpensive stuff to fix in most cases.
How many miles on the odometer?
Andy
Andy
This is like 20 questions - I'll play. Are you saying you can't get the car into third gear at high RPM's? Worn engine mounts or a worn transmission mount??
Into the reverse gear, the engine speed 400-600 rpm, can not return to normal idle speed, in this situation has continued, but into the D file, the idle speed returns to normal.
In the 2nd gear, the engine speed is 6000 rpm, there is no way to automatically enter the 3rd gear.
Under normal circumstances, the second gear engine speed 3000rpm, will automatically enter the 3rd gear.
Seems like some sort of vacuum leak that influences the idle speed and ability to shift correctly. Look for leaking vacuum actuators or vacuum lines that have slipped off.
Just some guesses.
Just some guesses.
