TPC SUPERCHARGER & PROMOTIVE TUNE , NEED INPUT ON FUEL INJECTORS PLEASE
I was told that the Sieman Deka 60 injectors are somewhat decent. However, i did a little research and found they are not quite as good as the Bosch injectors.
Anyone with a Promotive tune care to chime in with recommendation and p/n's?
I used EV1 36lb injectors - I think the brand was Viper - I'll check when I get home later.
36lb rated to match around 13-14 psi. Stock TPC pulley runs 6psi max.
To get the right fueling we added a 4.5lb FPR. AFR was great after that.
Todd sold these - they where used on his 964 stage 2 kits.
Price back then in 2011 was $490 a set.
In hindsight - I'd just go bosch turbo units. Not that I had problems with the units I used for over 5 years.
Piece of mind, reliability, and you can resell later on.
Turbo injectors are about $127 bucks each x 6 = $762. That's not bad.
Once you got them - Todd can get a good tune for you.
So... where did this end up? Sounds like the 'best' plan for a TPC supercharger install is to dump the 7th injector, go with oversized Boxster /997 injectors instead, dump the split second box and get a Protomotive tune. Any view on the pulley?
How does the tune at Protomotive work- do they need to see the vehicle in person or do you send them the ECU with a list of the mods?
I remember the smiles that the SC put on my face. Great upgrade.
Mine came off when I went back to stock and did a top end rebuild.
It's sitting on the shelf doing nothing. Maybe destined to be reinstalled one day.
But if anyone is interesting in buying one - pm me.
I guess you have a choice. Original NA 993 injectors flow about 22lb/hr, so either would work. My choice (and I had the same options in front of me) was ultimately determined by advice that the Boxster injectors were of a more modern EV14 design, more controllable, good for 490bhp and more readily available.
Todd said they should work, he was looking for 36 lb injectors. I can upgrade to a adjustable fuel pressure regulator to get the extra.
I am still in a hold patern. With OBD1, I am having trouble with finding a data logging option.
