TPC supercharger MIL-STD-WD - Rennlist - Porsche Discussion Forums
993 Forum
Old 03-11-2018, 01:39 PM
windydog
User
windydog's Avatar
Default TPC supercharger MIL-STD-WD
A thread dedicated to my install.
I was thinking about this, why hasn't anyone utilized a flat intake for the engine that would pull air from the decklid.
I did, and I am going to play with the idea.
Get rid of the cone filter which has proven worse hp figures
Stat tuned for my trade study.
windydog is offline
Old 03-11-2018, 03:19 PM
Meenrod
Meenrod's Avatar
Cool. Subscribed.
Meenrod is offline
Old 03-11-2018, 03:59 PM
MarinS4
MarinS4's Avatar
No intercooler?
Feeding the SC with cooler air is always a good thing. I don’t think the tins do a great job of keeping heat out of the engine bay. With your non intercooler setup cooler air becomes even more important.
If if you can find a way to pressurize the air (scoops etc) coming into the SC even better. This will also lesson heat and make the SC more responsive.
Are you running 91 oct? If so some water injection would be a good idea. Better yet run E85. Its a great fuel for non intercooler setups.
MarinS4 is offline
Old 03-11-2018, 08:54 PM
windydog
User
windydog's Avatar
Tap for tach
High quality stuff
MarinS4 : You are correct, an intercooler is required. I am getting a free intercooler (air/air) and will be developing ducting.
To run E85, i would need to get a tune to take advantage of;
I was playing with the idea, because anyone who works with me know i am slow and think things out. With a little one, no much time to do trial and fitments, so i need to make it count.
There really is no way for me pressurize the air coming in, i basically removed my automatic tail and put in a SS304 mesh grill. I fabricated it for 50 bucks.
I will draw somethings out and go from there.
For the meat/potatoes of the build.
I really hated that crappy tensioner that is connected to the engine carrier. There are three joints which allow for misalignment. I understand why they did it, but its crap IMHO.
I was looking into having a billet part machined to support the tensioner, then Trevor-UK gave me a solid idea! Thanks Trevor.
I went with a Clewett setup, this was not cheap since you need to buy the setup and another pulley to account for the undersized pulley.
Total cost upper is 750 bucks including the new belt required: 6PK1195
In the event I want to reverse the process it will take 1 hr since everything is connectorized and i have the Clewett setup.
The Clewett Pulley on the crank measured at: 4.226
The TPC Pulley on the crank measured at: 5.26
The Pulley on the SC measured at 3
Taking ratios, and an integral i came up with a 1.75 ratio for the TPC set up. My system is an older one which has 5 psi of boost.
Therefore i needed a 2.4 in pulley, but decided to go with a 2.3" pulley which will yield a whooping 5.25 lbs of boost.
I also did some research and found the Eaton M90 peter out at 12k RPM.
The Installation:
The kit is by no means built to aerospace tolerances, +/- 1 inch more like it. I am used to +/- .010 on a bad day.
I had to shim and reshape many of the brackets, which added much time.
Its getting late, so i will continue the story later. To the many people who gave me good advice or answered my PM's thank you!!
To the trolls that want to criticize, may you find yourself with Diarrhea with not a toilet in site!
windydog is offline
Old 03-12-2018, 12:17 AM
nine9six
nine9six's Avatar
MIL-STD-WD,
All of your pulley sizes are in inches, yes?
Assuming TPC engineering factored in a 50% stress safety margin; I would imagine 6 PSI of boost would not hurt a thing, considering turbo boost numbers.
Your quoted ratio of 1.75; is this the same as 1/.75 or 1:.75?
Please pardon my ignorance, but I always thought ratios were expressed with, : or /...or did you mean 1: 1.75? I'm confused...
I'm confused as to how the above statement is relevant to your TPC supercharger install? Could you please clarify?
Subscribed... can't wait to see how this turns out!
My best!
nine9six is offline
Old 03-12-2018, 11:35 AM
Porsche-ah
User
The pulley's that come on the TPC superchargers later on was 2.8. Tom over at TPC ended up giving me a 2.5" saying it would slightly over drive the system for more power.They found that on the early kits the 3" pulley was slightly too big. You may want to recalculate.
Porsche-ah is offline
Old 03-12-2018, 11:29 PM
windydog
User
windydog's Avatar
9nineSix
The ratio i am reffering to is more like a scale factor. I took the TPC pulley crank and SC pulley to determine a scale factor. I did the same for the Clewett pulley to determine final size of the SC pulley to account for the under drive.
The 12k refers to the Eaton M90 pulley which is used in many cars and application. This is information for the engineer in me.
For the 3" pulley, i called TPC today and talked with Tom.
SInce i am running the Split Second box, its not as quick to react to retard timing as the newer piggy backs. Because of this, there is a little safety built in at 3 inches. I am opting to run a smaller pulley at my own risk.
For the Flat intake, i tried to see what the stock box would look like. The blow off valve is in the way, so more thought is required. I am planning to mock up a cardboard box to see what something could look like. I will then seal against grill cover to get air into the engine.
More to come.
windydog is offline
Old 03-13-2018, 12:33 AM
nine9six
nine9six's Avatar
WD,
Thank you for your clarification...So the Eaton M90 is the same supercharger that is applied too many different vehicles; including the unit TPC adapts and sells as the Porsche 993 SC kit. Interesting.
nine9six is offline
Old 03-13-2018, 07:55 PM
OverBoosted28
OverBoosted28's Avatar
And what does she get to do, once you’re finished “dressing her up”? :-)
OverBoosted28 is offline
Old 03-13-2018, 09:14 PM
windydog
User
windydog's Avatar
She gets to drive me and my son to car events to meet great people like you!
Aloha brah
windydog is offline
Old 03-15-2018, 12:08 AM
mr_bock
User
mr_bock's Avatar
Nice to see some creative juices working some modifications to the modifications. I have had my TPC Supercharger for more than ten years. No issues, lots of fun. Did a number of Performance Driving Experiences at Summit Point, Sebring, Daytona Rolex course. Now a days I do AutoX in central FL.
I did not go for the inter-cooler and have not had any problems, ping, or other. It was bolt on 120 hp.
For me, the SC is the best Bang for the Bucks.
Good Luck on your project!!!!
mr_bock is offline
Old 03-15-2018, 03:58 AM
samurai_k
samurai_k's Avatar
@windydog I admire your creativity and engineering here!
I have recently seen a few used GT2 like spoilers for sale, perhaps you can improve the flow of cold air with that spoiler as they have those scoops?
samurai_k is offline
Old 03-15-2018, 04:25 PM
nine9six
nine9six's Avatar
I like Samurai's thoughts...If you could use that tail to pressurize an air box that feeds the SC, I think you'd be set!
nine9six is offline
Old 03-16-2018, 08:54 AM
jstyer
jstyer's Avatar
Let's super duper simplify this equation (ignore stagnation temperature change, ignore the fact that we're not even at true stagnation, ignore comprehensibility of air... etc.)
So theoretical best case scenario, before accounting for any losses, gives you a max stagnation pressure of .176 psig at 100mph. i.e. not a lot. Focus on getting cool air. The idea of "pressurizing" an intake on a normally aspirated engine without extremely in depth flow analysis is pretty silly. Especially when you're already doing forced induction, if you need an extra .176 psi, well, that's an easy get.
jstyer is offline
Old 03-16-2018, 03:12 PM
nine9six
nine9six's Avatar
I'd venture to say it's not that simple; despite pressure of .176 psig at 100mph...
https://sciencing.com/convert-wind-s...i-6003776.html
nine9six is offline
Contact Us Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
Question Title:
