TPC supercharger MIL-STD-WD
#47
Originally Posted by joe [email
original@flash.net[/email];14902545]
The brake booster hooks onto the back of the manifold .
I have a catch can for the oil event with a Canon filter on top of it .
Hope that helps?
Hope that helps?
Thanks!
#48
Was getting ready to install with 996, and the stupid throttle cable bracket I recirece with the kit did not work.
Rather than half *** it, I made a bent up sheet metal bracket using a vise and a pipe as a die.
TRW.
I'm famous.
TRW.
I'm famous.
#52
Installed, but what to do with the vent hoses?
https://rennlist.com/forums/993-foru...installed.html
#53
Which hoses are you referring to? Can you circle them in your pic?
I have one going back into the intake rubber boot and the other to the K&N
Carbon canister tube I have it connected to one of the barbs on the back of the intake manifold.
#55
Update
Was thinking I would start the car today, but ran into 2 issues.
1) Had to trim the back of the supercharger to allow the connector to mate.
2) still can't get 12 v power to power split second. I used the SAI relay location, I had the dme relay installed and get 1 volt....
The trim
This sucks
How am I supposed to mate
The trim
This sucks
#56
Thank to Andreas again. That guy is so helpful.
Figured out the 12v issue prr his advice.
The mistake I was making was the ground. I moved the ground to the lug in the driver side engine bay and 12v switched power.
Now all I need to do is hook up vac lines and I can start the car.
With family and upcoming meeting at work. Might be 2 more weeks.
#57
Courtesy of Andreas
