Non-Hifi Front Speaker Upgrade - It's 2018!
Have you considered going retro cool with the OE equipment?
I am also looking at the audio control DSP amp which has speaker level inputs so can handle a head unit without rca line out. The OE CR and CDR head units have a line out via an adapter based on some quick research...
https://rennlist.com/forums/993-foru...ages-info.html
I like the Sony as it has Bluetooth input already integrated. This audio control will need a bluetooth to rca line in adapter which JL audio makes.
https://www.crutchfield.com/p_161D4800/AudioControl-D-4-800.html?tp=115&awkw=191387565385&awat=pla&awnw=g&awcr=99516645385&awdv= m&awug=9031973
https://www.crutchfield.com/p_136911...io-MBT-RX.html
https://www.crutchfield.com/p_136HD6...-4.html?tp=115
https://www.crutchfield.com/p_091FDP...00.html?tp=115
https://www.crutchfield.com/p_500PDX...F6.html?tp=115
My rear 4x6s can run off deck power for a bit of fill.
For what it's worth I just visited this problem last week. I have a 1997 c4 cab and I replaced a door handle gasket and fixed my door pockets with reinforcements this past week. In the process I noticed that the original speakers were virtually deteriorating (I have the "hi if" option without the dsp). Extensive searching of the forums here and talking to local car audio experts (in KC) I basically gave up and replaced my speakers (all of them) with original factory stuff from sunset Porsche. My system (the hifi) is complicated by the ohm rating of various speakers and the under passenger seat amp. 4ohm 5.25" woofer, 6ohm 3" midrange, tweeter that's impossible to replace in the factory piece, and a rear speaker that's 4" and 8ohms. Really?!? Anyway the OEM stuff HAS to be better than 21 year old stuff that was there! Of note I replaced my factory radio with the Porsche classic....I like it although I know there is better aftermarket stuff!
In my case I wanted to keep the factory stock look and maybe get better speakers. I didn't like any of the limited options. I WILL say that replacement OEM stuff was dirt cheap for Porsche stuff (20-30 bucks per speaker generally). And this coming from Porsche! Must be REALLY cheap stuff but it fits.....
- Yes you may need to understand how to fit the grill or get generic replacement ones from Crutchfield, not sure this is a big deal as measuring what you got and a phone call to them can probably sort this out.
- If there is a special plug on the speaker Crutchfield will have an adapter or the plug on the original one can probably be cut off and mounted to the new speaker or a pigtail can be made from it if you don't want to just splice into the old wire. Adding a splice preserves the old pigtail wire if that is your aim while a soldered splice is very reliable. You can then just wrap the old terminal in some electrical tape and leave it in the door. Same deal for the back speakers.
- If you get the most common coaxial design where the tweeter is in the center of the speaker you can simply disconnect the OE tweeter and run with the replacement speaker only. I found reusing the original tweeter with its built-in simple capacitor crossover can sound quite harsh. I ended up just leaving it disconnected and ran with the tweeter in the aftermarket speaker.
Andy
Sony just released a nice class D amp with DSP and Bluetooth. Looks like it's not available yet...
I'm quite impressed with the new Class D amps as they are very small yet provide a lot of power and pack in many other functions that you used to have to integrate other things making it complicated system.
Class D Description
Andy
I would only consider a class D amp that gets consistently great reviews and I can listen to in a shop first before buying:
Class D Description
Andy
Class D Description
Andy
Everyone's definition of SQ (sound quality) is different. What might be great for some is indiscernible or inadequate for others. To each their own. I unfortunately been a audio nerd for a while so do like to have nice audio equipment for my office and desk as my reference are Sennheiser 650s and a schitt DAC/class A desktop amp.
At some point the difference between different quality speakers and amps becomes difficult to differentiate as the differences are subtle and again dependent on the person and content which is why you should go listen with your tunes yourself and be the judge. In a car, SQ is challenging given the road and engine noise you have to overcome (Fister mufflers and all the mods we do to harden our bushings etc... do not help) so you really can't expect critical listening in our cars. I do think the difference between an amplified vs a non amplified system is noticeable when you have decent speakers as the speakers are just playing what is sent to them. The hifi systems are starting from good place already as they have an external amp.
This thread of course is about our stock non hifi systems which is why I am making the case of decent speakers with a decent amp with some sound processing will go a long way. That is what modern car audio systems have as the "premium" audio option.
I’ll further add, if you go with those focals, heavily consider a 4 channel amp. Especially since you most likely won’t have a sub in the car. Bi amping will yield much more control and better sound. This is the amp my stereo shop swears by. JL XD400/4v2 https://www.crutchfield.com/p_136986...m&awug=9031595
Also I believe you can fit those tweeters in the OE tweeter pods. I saw a thread a while ago where someone did that. They siliconed them inside the pod. Definitely try them pointing in several different positions first. Tweeter placement makes a huge difference in sound.
I agree with you Andy. True with any of these audio purchases to go listen to the speakers and amps at a shop with your favorite tunes.
At some point the difference between different quality speakers and amps becomes difficult to differentiate as the differences are subtle and again dependent on the person which is why you should go listen yourself and be the judge. In a car sound quality is challenging given the road and engine noise you have to overcome so you really can't expect too much critical listening. I do think the difference between an amplified vs a non amplified system is noticeable when you have decent speakers as the speakers are just playing what is sent to them. The hifi systems are starting from good place already as they have an external amp.
Thanks for posting this thread. I too am in the upgrade process and nearly everything I found using searches was outdated.
My car is a C2 Coupe that came from the factory with the standard 2 way system. A previous owner installed an upgraded system, but as a music producer I have picky ears, and want to get the best sound I can while still looking as stock as possible. The car currently has Polk Audio 2-ways installed, an MTX 4x50 watt amp in the frunk, and a Sony head unit with bluetooth, etc.
After some lengthy listening sessions with a wide variety of music types at a local car audio shop, I decided to go with the Focal Flax 2-way system mentioned above. I think they have a quite natural sound and were better than the other speakers I auditioned. The only other pair that I wanted were Arc Audio Black speakers, which were a little more neutral than the Focals. They also had slightly better bass response. But they were 50% more expensive and the A/B with the Focals was too close for me to justify the extra expense. According to my installer, and also Rod at Car Audio Innovations, the Focals will fit in the stock locations/grills.
I read a lot of good things here in previous threads about Rod and his expertise working with 911 installations. So I called and he couldn't have been more helpful. After several conversations, in which he thoroughly answered all my questions, I decided to add sub enclosures in the rear footwells to complement the 2 way Focal system. I don't use the footwells, and the enclosures Rod builds for the 993 can go in and be removed without mucking up the original interior.
I am also going to remove the amp from the frunk, and replace it with a newer Class D amp under the passenger seat. Rod recommended the Alpine PDX V9 amp as great fit for that application, but I have access to a used ARC Audio xdi 1220.6 6 channel amp, which I am going to try first to see if it fits.
Not sure yet if I'll bother connecting the rear deck speakers to my head unit for fill, or just go with the Focal/JL Audio sub combination.
Hope I didn't hijack the thread, but thought I'd post my experience thus far. I can post more info and photos once the installation takes place if others are interested. Have to give a shout out to Rod at https://www.caraudioinnovations.com/. He really knows his stuff and was very generous with this time and knowledge to help me, even though I'm having the installation done locally in SoCal.
If anyone wants my Polk Speakers as an upgrade from the stock ones, feel free to PM me.
Originally Posted by Mark in Baltimore
Great thread. Does that Continental radio allow Pandora to be streamed from it? I assume so but didn't see any confirmation in my Google search.
Thanks for everyone's input here so far. I consider myself less of an audiophile than most of you seem to be, but I decided to take a route that is open to extensions later on:
- Replace the front speakers with Focal Performance Expert FLAX PC165F 6.5". For sale by a German shop for roughly $240. Since these are coaxial speakers, I'll disconnect the OEM tweeters. I doubt I'd notice the additional SQ from separate tweeters and it keeps the door closer to stock without the need for glueing tweeters into the pods. I hope they are an easy fit, perhaps @BeauBlues, @L39E, 95_993 can chime in. Crutchfield says they don't fit and this thread looks terrifying but isn't really comparable since he tried fitting two speakers in one door.
- At this point, I'll assess how I like it. If the power isn't enough, adding an amp and replacing the rear speakers are always options as I went with quality components to begin with. I'll be sure to properly document fit and improvements once this is built in.
- I'll disconnect the OEM tweeters.
- If the power isn't enough, adding an amp and
- replacing the rear speakers are always options
I did a whole system upgrade. Sounds decent and didnt break the bank. I did 6.5 separates in front and 4x6 in back by JBL. It looks great and sound is good. Not a ton of bass, but no speaker brands will. For the radio I did the new Sony that has a built in amp 100x4 (45w rms). Sounds super clear even at 80% volume. You have to run a 12awg wire from the battery. Additionally I put in some sound deadening in the doors. No rattles and sounds solid. For the 4x6 I bought aftermarket grills that worked great.
-6.5” speakers fit. Do a search and you’ll see more than a handful of threads showing that.
-Don’t do coaxials. Those highs are meant to be close to your ear. It’s not that hard to modify or replace the existing tweeter pods.
-Get an amp. It’s not about volume. You’ll get more clarity and your speakers will last longer.
Do it right the first time and you won’t regret it later. It doesn’t have to be expensive either. Remember, YouTube is your friend. Also, ask any of us here for advice if you get in a jam.
