Elephant bump steer tie rod spacer advice?
I am going to put in some new solid tie rods from Elephant. My inners were worn so decided to get these instead to replace both the inner and outer at the same time.
They come with multiple spacers to adjust how close you want the tie rod to be to the knuckle/carrier, which can impact bump steer. I don't want to shell out 2k for custom RS carriers which is the real solution to this problem.
My car is right above RS height.
Have any of you used this kit before and can send me a pic or let me know how you have installed the spacers.
The tie rod ball joint is long and my pss10s get in the way which means I have to take off the struts from the carrier if I want to change the sequence of the spacers.
Thanks!
Thanks!
Haven't used those, but what you want to do is get the tie-do end to sit about parallel to the ground (level surface). When you lower the car, without any change in tie-rod geometry, you've removed some of its travel. When it runs out of travel, that's where the "bump steer" is induced. Use the spacer to get end of tie-rod back to neutral position of its travel. Hope this makes sense. The car's suspension should be loaded. Obviously the RS carriers, and corresponding outer tie-rod ends, set the geometry.
Correction: the tie-rods need to be lowered, so they're level with ground.
I just shot an email off to Elephant with a similar question- specifically what ride height range is optimal for use with this product. The instructions state to measure bump steer with the spacers in various arrangements but without access to a bump steer gauge I hope for some advice for at least a ballpark starting point. Im pretty sure my car is well below the ideal geometry for the stock uprights so my guess is that the total 3/16”s of spacers will end up in the “maximum” location below the steering arm. Mines a 964 and not sure if there’s any difference between the 933. If anyone can clear that up I’ll post whatever reply I get in this thread.
For others following along here here are Elephants instructions :
https://www.elephantracing.com/suspension/instructions/2180018_Bump-Steer-Correction-Tie-Rod-Kit-Instructions.pdf?iframe=true&width=80%&height=95%
pete
pete
https://www.elephantracing.com/suspe...80%&height=95%
pete
pete
I put the spacer at the bottom. My kit only came with a thick spacer. I called and evidently newer kits had a revision and now come with only one spacer. To get the most correction all spacers go under. At RS height I would assume u want the most correction as possible. I saw a reduction of bumpsteer of about 80%. Feels way better and steering got slightly more responsive removing inner tie rod rubber. Was hoping to get zero play, but I guess there is nothing left to fix in an older car.
If Elephant is supplying only one spacer now. I don't see the use of such a long stud.
Sorry forgot to update this thread. The upgrade is great. Noticable improvement in steering responsiveness. I am close to RS height and the steering is less twitchy over bumps. I cross a long bridge on my commute and with this upgrade while there is still some bump steer, it is less noticable than before when I go over the griders.
Here are a few pics. I elected for maximum correction which puts the spacers on the bottom. I have more pics in my build blog in my signature. Thanks
Awesome! Thanks so much. Did you have to remove the shock to install these?
Also if it's no trouble... Do you have a side shot of your car? Just so I can visually reference your ride height against mine?
***EDIT***
Found all the pictures and answers I needed in your build thread... Very impressive might I add!
***EDIT***
I had to remove my strut to get the room to install. Didn't matter since I needed an alignment after anyways. Made it slightly more difficult, but not much. I still like mine. I rarely ever feel bumpsteer now. Cheap alternative to replacing the Carrier/hub. It isn't perfect, but for the price I am happy I bought it. Also stock tie rods looked rusty and were 10 yrs old. I also did new poly bushings on the control arms. Front feels tight now.
