Engine doesn't start
A scangauge is also a good tool - you can look up\clear codes as well and shows you some other numbers.
Alternator - are you on the original? how many miles on the car? might be time to just swap out for a rebuilt unit and start fresh. the shaft design is a bit tricky and you have to be very careful! the metal the socket goes into is thin and easy to strip :S
phil..
phil..
