Want Absolute softest ride 993
#47
Thank you for the “gentlemen”. Just wait, we all get older eventually.
I have Z rated tires and have new Rossos on order. Their is 2-3 month back order. No othe r options for 16” wheels.
#48
"Softest ride" in our cars is an oxymoron. Get contoured gel seat cushions, heated for the "older gentlemen", for < $100. Spend the $ saved for a hard tour to Zuffenhausen, beer, pretzels, wurst.
#49
From Tire Rack, other charts are available, shows relative changes in tire pressure based upon expected top speed. In my C4S, the plate says 36F/44R which is good for the expected top speed of approx. 180. I am never ever going to get the car to 180 in the US. I am always 2-5 pounds lower.
#51
RL Technical Advisor
#52
I lowered the tire pressures as suggested and it is noticeable but still a harsh ride. I would not recommend the B6 HD to anyone.
#54
The beauty of the PSS10 system is that the valving is digressive, and the springs are matched to the valves. This is key to a good suspension system, which is why they ride so much better than the B6/B8 setup with whatever springs.
There aren't many alternatives to the PSS10 in this price range, KW comes to mind. If you want the ultimate, be prepared to spend a lot more.
Finally, my understanding is that the B6/B8s are not rebuildable. If this is true, I would avoid them.
#55
Mac- I'd do a quick search and read up on endless suspension threads here. You'll discover that HDs are stiff regardless what springs you use. Some springs are more compliant than others. As mentioned before, if you want the softest possible, I recommend PSS10s. When set on 1 (1-10), the ride is soft and most comfortable of all the combos I've had on the 993s over the years. I've had PSS10s, HD/Eibach, HD/H&R, HD/M030, and Koni Sport w/adjustable dampening. I'm no suspension expert, but I speak from experience with these set-ups. Hope that was helpful.
As Quad mentioned, lower your psi will also help.
Thanks,
#56
At the risk of making a very simple recommendation, why not get the M033 kit with plain old Monroes? Quite a few years ago, I purchased a M033 kit for the '95 before the prices went ballistic and finally got around to installing same a couple of years ago. It gave me the Euro ride height and a nice, comfortable ride that I would gladly drive from here to Hell and back. It is "Dr. Jekyll" while the '98 C2S is "Mr. Hyde".
#57
Mac, I am glad there is some improvement with lowering the tire pressure. You say you are getting new tires, but you haven't answered the question on how old the tires you are running are. How old are they?
#58
At the risk of making a very simple recommendation, why not get the M033 kit with plain old Monroes? It gave me the Euro ride height and a nice, comfortable ride that I would gladly drive from here to Hell and back. It is "Dr. Jekyll" while the '98 C2S is "Mr. Hyde".
#59
For best ride quality, I'd use the OEM Monroes with stock springs and accept their limited lifespan as part of the compromise.
#60
Old 6+ years. I also have 17” wheels with new Michelin and still rides harsh. Tires cannot make up for this harshness. I don’t think the B6 is a shock absorber; it is just a shock when you hit even typical road deformities; they don’t appear to absorb much impact.
