Want Absolute softest ride 993
#31
The owners manual recommended 2.5 and 3 which is what I have always used.
Has anybody used the Porsche classic shocks?
I thought hard on getting PSS10S but I have no use for the adjustments and figured it was overkill for my requirements although if that is what it takes to have a good ride so be it.
#32
#34
Might want to check with Darin @ FD Motorsports, https://fdmotorsports.net for general information. IIR, the recommended setting (PSS10) was something like 4&6 on the dampers. I found that too harsh as I don't do very aggressive driving. Found that the front setting was too stiff so I backed it off to 1 and set the rear at 4. Seems to be closer to stock ride but the MO33 spring may be more stiff than OEM/USA. Of course, I'm no expert on suspension........
#37
That will only lower the ride height, It will not soften the ride.
Also, make sure you're reading the correct row on your car's tire pressure sticker. On my car, it lists 2.5 / 36psi front and rear for 17" tires. It also lists a higher pressure, but not for 17s.
#38
ok thanks
#39
Otherwise, pretty good at less than 1/2 the cost of PSS10.
17's run 36 all around, and that's what I would try on the 16's - maybe even a few pounds lower to see if it rides to more to your satisfaction. Give it a try and report back!
Cheers
Matt
#40
#41
Administrator - "Tyson"
#45
I recently changed tires on a RS6 that were 10 years old. Ride was horrible before! After new pilot super sports the ride change was remarkable.
I played with pressures a lot a lot on mine and settled with 33 front and 37 rear on PS2 tires. Going over 35 front and 40 rear made things quite harsh.
