Guard Transmission 2-piece main and slide on 2nd gear set
Does anyone have experience with this product? I have a 1997 C4S and I am contemplating a re-gear. I have heard that Guard offers a replacement main shaft with a slide-on 2nd gear to replace the stock main shaft with machined-in 1/2. I can't find any information about this product. Is it compatible with the C4S AWD? And what are the 1 and 2 gear ratios? I was contemplating going with the Guard 1-2 and the RS 3-6 gears, but I'm not savvy enough to know whether this would make a good close ratio gear box.
Matt - I thought about your car, but since it was a 1995 I assumed that you had the changeable second gear. Now that I think about it, Bill showed somewhere that the changeover was during the 1995 model year.
http://www.guardtransmissionllc.com/...ets/993-gears/
https://rennlist.com/forums/993-foru...mainsheet.html
A little extra info for you guys.
I was contemplating Guard 1st, stock 2nd, RS 3-5, moving stock 5 to 6. Based on Bill's good work, the ratios would look like this:
First: Guard 3.5
Second: Stock 2.048 (21:43)
Third: RS 1.522 (23:35)
Fourth: RS 1.242 (33:41)
Fifth: RS 1.024 (41:42)
Sixth: Stock 5th 0.921 (35:38)
Do any of y'all have an opinion on these ratios for a close ratio gear box?
First: Guard 3.5
First: Guard 3.5
First: Guard 3.5
First: Guard 3.5
First: Guard 3.5
First: Guard 3.5
First: Guard 3.5
you want a wider spread
W/ a stockish motor and tires look for drops of ~ 37% 24% 18% 17% 20%, your money gears are 3 - 5 speeds of ~ 95 120 140 +/- work well for these, w/ a bit taller 6 for the interstates
That would give me Guard 1st, Stock 2, RS 3-6
I do consider the 2.00 a better choice. We don't use the same toothcounts that they do, which is why I almost always talk in decimal ratios for clarity. In general, we reduce the toothcount for added strength and durability. The trade off is that's part of where the added noise comes from. For example, on the 2.00 ratio we do it as 16:32 versus 20:40. They do 1.521 35:23 whereas we do 1.526 19:29, etc.
