Valve Cover Gasket/Timing Chain Gasket/Hardware
Noodle Jr.
Just curious if there is a kit with all the gaskets and new hardware or do you have to buy everything ala carte?
I was advised to use Wrightwood racing viton gaskets over OE.
Patrick Motorsports sells them, I think they are 2 separate kits, 1 kit for valve covers, 1 kit for timing chain.
Just my 2c...
Just my 2c...
Subscribed
Curious about doing timing cover gaskets this winter as well. I'd like to try doing it without pulling the crank pulley. I've heard it can be done.
VC Bolts: http://www.autohausaz.com/pn/90006723802
VC Gasket Set: http://www.autohausaz.com/pn/99310590200
Timing Cover Gasket Set: http://www.autohausaz.com/pn/100912180
Or contact your trusted shade tree wrench
Noodle Jr.
Oh, a few hints as well:
- you will have some of the nuts come with the studs when taking the chain covers off. Remove the nuts and install the studs back with locktite. You do not want to install them like you took them out, you will be forcing the stud to turn inside the rubber seal and the torque might not be right.
- get a GOOD torque wrench, hopefully calibrated - 7ft-lbs is really small. I have a small Snap-on that I use.
- I use a light coat of Curil-T on the gaskets as added protection because often the channels the gasket runs in on the covers are rough, so everything helps
Cheers,
Mike
Why? - the crank pulley is a piece of cake to remove and install, and with everything out of the way, you can property torque all the holdown nuts.
Cheers,
Mike
Cheers,
Mike
7 ft/lbs = 84 in/lbs.
https://www.ebay.com/i/112615945502?...D1354298005961
Addicted Specialist
Question on the cam-chain cover gasket project, gents:
A wrench (whom I don't know well at all) told me that one doesn't just replace the housing gasket, but a "seal" or such inside as well, as this is "required" since it's this inner "seal" that's likely doing most of the leaking, and thus adding to the work the housing seal is trying to do?? Can someone shed light on this for me as I've never had to go in there? I'm contemplating getting this done so clarity on this would be greeeaaaat! TIA guys!
Edward
Edward
Edward
Edward
It's all thoroughly described in the link below. Note, that removing the timing boxes to get to these o-rings and gaskets will require re-timing the cams.
I borrowed some diagrams from that thread for illustrative purposes.
https://rennlist.com/forums/964-foru...t-o-rings.html
