Send Prayers
I will be getting mine done in spring. I have about 60,000 miles, 8 years of track, a long crack below the wiper blades since day 1, and a nice rock chip from last year.
With the track pitting, I am due and EXCITED.
Will let everyone know how I make out - and may be back with questions in advance.
Cheers
Matt
Cheers
Matt
Best of luck ... Connect to mapquest.com how far is Mountville, PA ???
Cheers
Matt
Cheers
Matt
I’d be right there watching making sure they install that chet correctly. Safelite did my WS several years ago with Pilkington. They showed me the channel prior to fitting new glass. Fit and finish were perfect. Good luck!
Noodle Jr.
I would definitely stay and watch. I would not let them install the outer seal (cover) prior to windshield install (they did on mine and therefore could not properly "center" the WS in the opening.) 90% of these guys are all about speed. And, you definitely want to see for yourself any potential rust.
You need a consistent gap all around, or the outer seal will not reach the painted surface, and will tend to fall in the gap. Also, they should not press the WS too far into the aperture or, again, the outer seal will not reach. Templates are available to confirm these things. You only get one shot to get it right. My installer would not touch it, even after I took it back and showed him the offset he created. Fortunately, after buying and returning 3 outer covers, I finally found one of the 2mm wider versions and it covers the gap.
Prayers are with you...
