993 Forum 1995-1998
Low clutch pedal - Loss of brakes
Old 09-21-2017, 11:20 AM
Frods
Frods's Avatar
Question Low clutch pedal - Loss of brakes
During driving the brake pedal went all the down to the floor. This happened a couple of times. In between the brakes were functioning normal. At the same time I also noticed that the clutch pedal was low, maybe 2inch of travel. Tried to pull it out to see if it was just "hanging" but that was not the case.
Anyone experienced the same? What could cause this? Master Cylinder?
Old 09-21-2017, 11:36 AM
mpruden
mpruden's Avatar
I'd guess you have a leak at or near the reservoir if losing brake and clutch.
Find out where you are losing brake fluid and get it fixed before driving!
Old 09-21-2017, 05:46 PM
nine9six
nine9six's Avatar
I'll take a stab at the brake master is going; and things need to be fixed before any additional driving.
You can bleed the brake system and clutch slave but if it's the brake master going, you'll just get more air into the system.
Quick Reply: Low clutch pedal - Loss of brakes
