New to the 993
Nothing against the 912E community, but switching from a 912E to a 993 C4 is a DEFINITE upgrade! Congrats and enjoy the new car. There is lots to learn from these forums. Do some keyword searching and enjoy!
This is a very helpful link that shows all of the different wheel weights, factory part numbers and offsets:
http://www.944racing.de/wheelweights.php
Thanks, 912E was my first Porsche, so it got me into the community at large. I always knew I needed a 911 eventually though. And to me 993 is the most beautiful iteration yet so that's where my focus was.
Speaking of Focus, my other car is a Ford Focus RS- and while it has a ton of grunt at 350HP, the visceral feeling of the 993 in 4th gear at 4k RPM is unmatched by any modern car I've driven.
I keep a running list of 993 maintenance and repair items and suggestions that may be useful to owners of cars with over 80K on the odometer. Since your's falls into this category here it is.
Understand I am not a professional Porsche technician so it may be valuable to vet some of it right here on Rennlist
Amazing, thanks! This list is very comprehensive and I've printed it out to go through it more thoroughly.
That sounds like a great plan. The Cup 2 wheels would look more period correct on the 993. I thought that those were Boxster wheels but it looks like they are 996 C2 wheels. This is a very helpful link that shows all of the different wheel weights, factory part numbers and offsets:
So I'm thinking I want to get rid of these 996 wheels and get period correct turbo twist wheels.
It seems most recommend a 5-7mm spacer if I switch to the 18" turbo twist, but will they otherwise bolt right on, or is the lug pattern an issue? Also, will I need to recalibrate the speedometer and odometer? I think I'll go for solid vs hollow twist since they're about half the price now.
Check out the pinned thread
https://rennlist.com/forums/993-foru...eir-993-a.html
There are so many pretty wheels to choose from...
Also here is where I got my info to get the right offset as I went with an aftermarket set from Work
https://rennlist.com/forums/993-foru...-question.html
That Sony unit looks like a great alternative to mounting my iPhone on the dash for navigation. How far does the screen project out from the dash? Is anything blocked besides the ash tray?
I'm also interested in your review of the Sony H/U. Not to derail your welcome thread (welcome, by the way), but could you post a couple bullet points about the headunit that might not be glaringly obvious until living with it for a while?
It is definitely a good alternative, since you'll get Carplay on the dash. I have not used Carplay, but if it is anything like Android Auto then you'll understand why it was so important to me to have it in every car.
One thing I have to say is that I use Android Auto exclusively on it, so the software on the unit is not really important to me. As an Android Auto device, it is absolutely perfect. Perhaps better than the factory Sony unit in my Focus RS, since the Ford Sync3 software isolates audio and phone volumes (not really a big deal). This screen is definitely sharper than the Ford too.
I also needed something with a proper volume control **** as I don't like controlling volume with buttons. So this really hit the mark.
M. Schneider (05-31-2021)
