Muffler experts- need help ID these cans
I have Stage III's and love them. They are decently loud but not too much for me. In cabin they are relatively quiet around town and highway. The only issue with noise I've had: living in a cul-de-sac on cold days, the start up was loud enough to **** the neighbors off a few times. Also in tight streets, if you goose it in 1 or 2 gear, you can set some sensitive car alarms off.
Guys,
I found this part number for the bischoff Gillet donut is this correct?
928-111-246-05
http://www.pelicanparts.com/More_Inf...=Y&SVSVSI=.htm
Other than needing two of these anything else needed to install bischoff cans in my Gillet based car?
928-111-246-05
That should be it. https://www.porsche.com/all/media/pd...SA_KATALOG.pdf Illustration 202-00. As long as you have the clamps, bolts, nuts and washers, you should be set.
