Differences in a 3.8?
#32
As MarinS4 has mentioned, A compression bump and some happier cams goes along way in waking up these engines. As Steve W will attest to, the stock compression on these engines is never much over 10.8:1 a long way shy of the advertised 11.3:1.
Gaining that 'loss' back and some cams that open her up makes a significant difference and the spend is substantially less that a full displacement build (which should also include cams etc).
I am personally a fan of happier cams that the RS, however that does bring about a need for solid lifters and could make it a challenge with any smog testing requirements.
As for turbo's etc, it really comes down to cooling design and execution, heat is a killer for turbos and doubly so for air cooled engines, substantial oil cooling and intercooling is a must, many guys on the 993tt forum know the right formula, MarinS4 included.
I love turbo Porsches, however on the track there really is something special about a camed NA engine running to redline...
#33
Compression bump
#34
Compression is driven by piston and heads, and their relationship, you could put new pistons in exiting cylinders, that would be the best/cheapest way to go.
#35
Compression Bump
The old school method of decking can be done to an extent, however there is a limitation to ensure the deck height is still within spec. Steve W would have better knowledge here on how much can be achieved (if any) here.
#36
RL Technical Advisor
#40
#43
Getting my motor back soon. 1990 model. New Mahle P&C's and over-milled the heads slightly. Reportedly 11.05 to 1 on compression now. Stock cams. Running 93 octane and getting Steve Wong to do his magic.
Any issues with this that you see Steve Weiner ?
#44
