Oil pressure light & ticking sound
Hello experts,
I have recently purchased a 993 and stupidly, I decided to get an oil change at just any service center.
Oil was drained, then 11 liters of 15-W50 (Liqui Moly) were added along with 2 cans of 'Ceratec' (Liqui Moly) and 2 genuine oil filters.
'Ceratec' is a liquid used for wear protection for engines, transmissions, pumps and compressors
Immediately after starting the car, the oil pressure light went on, and would only disappear after engine is revved above 2 RPM. it would come back at idle. I went for a 7 km ride, and straight to 'Porsche service center' .... oh, and engine was making a ticking sound ever since.
Service manager, advised that the 'Ceratec' has significantly reduced the viscosity of the oil, resulting the oil pressure light to come on. Also, the oil filters seemed to be very dirty.
I am freaking out right now, and scared the engine will need an overhaul.
Appreciate your help Pleaaaase.
thank you
Mutasem
thank you
Mutasem
I'm always sceptical when people start mixing and matching their own oil blend.. there is a real science to getting it right...
Apart from any better advice, I would want to get all that crap out of my motor asap. For now just use plain ole mobile one 15-50 it's a known entity... See if the ticking problem goes away and pray that the cams aren't scored...
Drive the car for a couple thousand miles and have an oil analysis done to check for metal.
Best of luck
Best of luck
Isn't that too much oil??
Hello,
Thank you for your help. All messages are being shared with the mechanic :-)
I believe the oil was drained from 3 different parts of the car. Two of which had a spring.
Another explanation I obtained, was that since the car has been dormant for 4-5 months, the additive has done its job and cleaned the system, and all the residue remained in the tray. Therefore, the residue along with the new oil, has been circulated back into the system and blocking the lifters. Also, I was advised to clear the tray and check the oil pump.
logical??
Mutasem
logical??
Mutasem
I don't think the oil & additive has anything to do with it low oil pressure will cause old lifters to click - as simple as that
3 drains & 2 springs??? DOH!!!
Was the 3rd the transmission?
Thank you for bringing this to my attention.
The air cooled cars in town are only a few, that's why expertise is limited, and I seek your help.
The first thing I will do tomorrow is request for a check up on transmission oil, and to check the oil pressure relief valve.
Mutasem
Mutasem
