Apple CarPlay question
Old Dec 17, 2023 | 04:26 PM
neil.schneider's Avatar
neil.schneider
Default Apple CarPlay question
Hi Guys,
I posted this on the turbo forum but didn't get any response.
When using Apple Carplay is it possible to rearrange the tiles to the right of the carplay?
I am new to 992.
Thanks.
Old Dec 17, 2023 | 07:03 PM
TK42ONE's Avatar
TK42ONE
Veteran: Navy
Yes you can do that on your phone under settings for car play then customize. Push on three lines and drag and drop
Old Dec 17, 2023 | 10:12 PM
neil.schneider
Thank you for the answer. I’m not sure I’m explaining it right. I know how to change the Apple CarPlay tiles. What I don’t know is just to the right of Apple CarPlay. The part I’m talking about does not look like it’s part of Apple CarPlay.
I think that’s part of the PCM. I have a 21 turbo S so it does not have the updated software. I’m trying to figure out whether those four tiles can be moved around or changed.
Old Dec 18, 2023 | 12:13 AM
aggie57's Avatar
aggie57
Yes, you can, Look up ‘configuring the info widget’ in our manual. You can also swipe up and down on that section of the screen to show other displays.
Old Dec 18, 2023 | 12:14 AM
neil.schneider
Ok. Thanks so much.
Old Dec 18, 2023 | 12:21 AM
aggie57's Avatar
aggie57
Found this in the owners manual within the Porsche Connect app:
Old Dec 18, 2023 | 10:28 AM
TK42ONE's Avatar
TK42ONE
Veteran: Navy
ah my bad! @aggie57 has you hooked up
Old Dec 21, 2023 | 10:34 PM
neil.schneider
I’m sorry to keep bringing this up. If it can’t be adjusted then that’s fine.
I am looking to adjust the tiles that I’ve circled. They are to the right of Apple Carplay. I think it’s useless to have navigation and phone in those tiles when you’re going to be using Apple Carplay for navigation and phone. I’d like to replace them with something else. I would also like to move the radio up to the top position. Has anybody made any adjustments in that area. I know I can rearrange the Apple Carplay section. I’m only looking to change the section next to Apple Carplay. Not CarPlay itself.
i’ve already tried changing the home screen. That did not change the section next to the Apple Carplay.
Old Dec 22, 2023 | 01:10 AM
mikey94025's Avatar
mikey94025
That part of the display belongs to the PCM not CarPlay, and is the Info Widget. Here is the manual page about configuring the Info Widget (Home / Options / Configure Info Widget, delete the tile you don't want with Activate Delete Mode).
Old Dec 22, 2023 | 08:37 AM
neil.schneider
Thanks Mike. I’ll give that a try. I already went to the home screen and moved things around to see if that would change the screen when carplay is on. It didn’t seem to affect it. I did not try deleting any of them. In other words, no matter what position I put things in on the home screen. When I go back to the CarPlay screen, those three tiles are there in the same position. Unless I’m doing something wrong. I really do appreciate you trying to help me. I guess nobody else uses CarPlay. Or maybe they just leave those tiles in the same exact spot. As I said, it doesn’t make any sense because two of the tiles cannot be used when CarPlay is on.
Old Dec 22, 2023 | 01:56 PM
mikey94025's Avatar
mikey94025
Just make sure you are editing the Info Widget and not the Home screen. Those instructions are the 2nd column of the manual page, not the 1st column. The Info Widget is the 2x2 tiles that appear when you swipe left from the right edge of the PCM screen.
Old Dec 22, 2023 | 10:34 PM
neil.schneider
Thanks for helping Mike. I will certainly give it a shot tomorrow and see if I can figure it out. Obviously other people have done it. I wish somebody would post a picture of Apple Carplay with something other than what I have next to it.
By Michael S. Palmer | 2026-06-09 16:47:52
