Cargraphic Valve Control Unit
Old 08-09-2024, 08:33 PM
  #916
SupremePower
Basic Sponsor
SupremePower's Avatar
Received 1,420 Likes on 833 Posts
Originally Posted by division
The shape of the box and orientation of the wires/cables which makes the previous aftermarket mounting solutions not compatible. So you gotta use zip ties once again or make your own mounting solution.
Our metal bracket still works the same with the new box. The only differences their logo will be inward instead of outward
SupremePOWER Inc
1562 Kimberly Ave - Fullerton CA 92831
Contact: sales@supremepower.com - Shop# (714)632-1951
World's Largest Retailer/Distributor of BBS Motorsport & Street Wheels from 2015-2023
Huge Inventory: BBS, Kline, Brembo, Soul, Recaro, KW, Akrapovic & 200+ brands. Installation available
** Retail & Wholesale ** Global Delivery ** We match/beat any authorized dealer's price **
SupremePower.com // SupremeForged.com // Follow SupremePower on IG
Old 08-09-2024, 10:29 PM
  #917
22992
22992's Avatar
My alternator cover mounted controller that most people shat upon and came up with a million other ways to mount is going strong after more than a year installed. Not a single error code or problem. Works like a champ at all times.
The following 2 users liked this post by 22992:
r4mi5awi (08-09-2024), SamD (08-10-2024)
Old 08-10-2024, 05:27 AM
  #918
Fullyield
Fullyield's Avatar
Received 1,565 Likes on 971 Posts
See post 895. Problem unit was attached to alternator cover …….although uncertain what is causing problems. My original mounting location was alternator cover but moved to Flat6/Supreme suggested location to reduce heat soak and vibration on electronics in the unit. Have had no issues with my unit in either location. Note the new version also lacks attachment ears.
Old 08-19-2024, 11:14 PM
  #919
PhilH930
PhilH930's Avatar
Installed Cargraphic ordered from Flat6 on 2024 GTS. I've only placed a few orders from @Flat6Motorsports , but every time they have been beyond helpful and fast shipping - thank you!
The open valves are more noticeable than I thought they would be and a nice third option to PSE closed/open. Install was easy enough, and a second pair of hands to gently pull wires more taught for cable ties beneath spoiler was great. Installed without ramps, which was a little tight but once situated all ok.
My only concern is the latest version of the Cargraphic (black box) came with version C non-invasive mount from Flat6. A nice add in to the purchase, but I am not confident in the tightness of the fit from the bracket, and would have preferred a solution that leveraged the 10mm oil fill hose bolt. As such I installed two cable ties on the mount; one around the non-invasive mount to the Cargraphic unit, and a second around the full unit and oil fill hose. Attached a pic of cable ties prior to reinstalling the engine cover (hence the filler caps off), along with image of version c mount.
My install
Stock pic
Old 08-20-2024, 04:23 PM
  #920
Picaso
Picaso's Avatar
Do you really need to take off the aerokit wing? Also how do take off the wing. Thats the only thing stopping me from buying this controller.
Old 08-20-2024, 04:59 PM
  #921
shrimp money
shrimp money's Avatar
Received 5,367 Likes on 2,135 Posts
You don't HAVE to. But it can make things easier.
Search the thread I created for how to do it with aerokit wing.
Old 08-20-2024, 11:14 PM
  #922
hopetogolf
hopetogolf's Avatar
I am considering this modification. If anyone is looking to get rid of their module that is fully functional and in excellent condition, reach out.
Old 08-21-2024, 08:08 AM
  #923
brandobot
brandobot's Avatar
https://rennlist.com/forums/market/1426347
i listed mine here
Old 08-31-2024, 02:44 PM
  #924
2ndgear
2ndgear's Avatar
Just mounted mine on the passenger side as per the Kies YouTube video. Piece of cake and the niche almost seems made for it. No need for brackets , zip ties, new parts etc.
Old 09-10-2024, 04:57 PM
  #925
traju
traju's Avatar
Selling my controller if anyone is interested
https://rennlist.com/forums/market/1430316
Old 09-10-2024, 06:49 PM
  #926
hopetogolf
hopetogolf's Avatar
Just installed this on a '21 C2S...knock wood...so far so good. It makes a difference and is an easy mod. For those inexperienced with sports cars and exhaust systems, I recommend you try this first before other changes. The ability to revert to stock on the fly is a nice feature. My wife loves going for rides in this car but I suspect she is not going to tolerate the car with the valves 100% open. So far, the one issue I have is I cannot get HomeLink to work. I can add each button to a profile but HomeLink does not change to the specific profile, it does nothing when the profile is selected.
Old 09-10-2024, 10:30 PM
  #927
Vicbastige
Vicbastige's Avatar
On the homelink screen try holding your finger on the screen for about the count of three on the profile name you have selected. What you report is not that uncommon and what I experienced until I realized you must hold your finger on the screen rather than just "tap" or push it. Mine works perfectly when I press and hold; hope it works for you.
Old 09-10-2024, 10:32 PM
  #928
PhilH930
PhilH930's Avatar
My homelink programming is intermittent at times, even with longer button presses. I just deleted the profiles and reprogrammed and working like new again. But carry the fob for back up and sometimes have to use.
Is a nice upgrade. Ready for some cooler fall weather with windows down, roof open, and a little extra sound!
Old 09-14-2024, 12:43 PM
  #929
Rezolution
5th Gear
Rezolution's Avatar
Does anyone have detailed photos of the install using the latest plastic bracket? Any thoughts on it's stability if mounted without zip ties?
Old 09-14-2024, 01:11 PM
  #930
Fullyield
Fullyield's Avatar
See posts 919 directly above????????
Post 917 shows an acceptable location also.
Quick Reply: Cargraphic Valve Control Unit
