Cargraphic Valve Control Unit
Old 08-01-2023, 01:10 PM
  #616
3rdpedal
3rdpedal's Avatar
Received 1,836 Likes on 956 Posts
Seriously considering this over the cost of the M-Tuner or a Tubi or other exhaust. Anyone who has had it a while that can share a review after having it on and using it for some time now.
Old 08-01-2023, 01:35 PM
  #617
jlegelis
jlegelis's Avatar
IMHO the controller is an economical 'gateway' to other mods. Depending on your needs you may find it to be 'enough' on it's own, but guessing it won't be if the rowdy Tubi appeals to you. YMMV.
Old 08-01-2023, 01:45 PM
  #618
Vicbastige
Vicbastige's Avatar
I've had it for about a month. Really a notceable difference for the money and, frankly, leaves me wondering if the extra money and effort are worth it for the Tubi (particularly w/o hearing the Tubi in person). Whats nice is that with the Cargraphic and PSE you essentially have 3 levels of sound to choose from. Closed, "normal" PSE and finally vales all in, all the time. I find I use valves closed for start up and leaving the hood and valves open all the other time I drive. The improvement of sound in the cabin is very noticeable and I assume even greater outside. This is particularly evident in low to mid-range RPMs.
I see it this way: try the unit and if it's not enough you could easily sell it here and move on to a more invasive and expensive option.
The following 4 users liked this post by Vicbastige:
3rdpedal (08-01-2023), Fullyield (08-01-2023), Icegrill (08-02-2023), SamD (08-02-2023)
Old 08-01-2023, 02:29 PM
  #619
Fullyield
Fullyield's Avatar
Received 1,565 Likes on 971 Posts
This mod is a good value at $600 and easy install. But, It increases quantity of sound only….not the quality of sound. It is a good “first step” and gives you plenty of time to decide on whether you want to also improve quality of sound with a more expensive catback exhaust or not. Same with a tune. Deciding on an exhaust is not easy since you cannot listen to them all in person. If you decide on a valved catback, keep the valve controller. If you decide on a valveless catback or a tune, sell it. You may decide the controller is enough. Buying Porsche mods for $700 or less are fairly easy decisions for me……compared to the $3,000-5,000 mods.
The following 2 users liked this post by Fullyield:
3rdpedal (08-01-2023), Vicbastige (08-01-2023)
Old 08-01-2023, 02:47 PM
  #620
VarTheVar
VarTheVar's Avatar
What's cool about it is it can still be used in conjunction with other valved exhausts, so it's not immediately obsolete if you upgrade. In fact if I got an aftermarket valved exhaust I would definitely want some way to force those valves open
Old 08-01-2023, 04:42 PM
  #621
3rdpedal
3rdpedal's Avatar
Thanks everyone!
Flat6 carries it?
Old 08-01-2023, 04:57 PM
  #622
Vicbastige
Vicbastige's Avatar
Thanks everyone!
Flat6 carries it?
Yep. A 15-20 min DIY...if you can lift your car a little to get your head under
Old 08-01-2023, 04:59 PM
  #623
Fullyield
Fullyield's Avatar
Thanks everyone!
Flat6 carries it?
The two vendors are Supreme Power who did a group buy and Flat 6 Motorsports. Good install video by Flat 6 Motorsport. RL member ShrimpMoney also did an install thread with photos which is good. Do the drivers side valve first.
Old 08-01-2023, 06:06 PM
  #624
Shogunade
Shogunade's Avatar
Received 2,193 Likes on 1,209 Posts
Well said.
Except I had no qualms dropping money on the JCR exhaust but agonized for days on buying a $60 elephant grille badge.
Old 08-01-2023, 09:33 PM
  #625
jhenson29
jhenson29's Avatar
Received 1,263 Likes on 514 Posts
I was able to install without lifting at all.
AdamIsAdam (08-02-2023)
Old 08-01-2023, 09:46 PM
  #626
Tobeit
Tobeit's Avatar
Received 1,521 Likes on 744 Posts
wow, I guess my head is too big, fingers too fat and arms too short…not a good looking picture in my mind. 😂😂 forgot, I am lowered and can’t even get a Jack underneath without driving on a 2x4.
Old 08-01-2023, 11:00 PM
  #627
shrimp money
shrimp money's Avatar
Received 5,367 Likes on 2,135 Posts
Don’t feel bad, my head was also too big. I had my friend drive onto some boards so I could get my head under his car.
Old 08-02-2023, 01:38 AM
  #628
3rdpedal
3rdpedal's Avatar
I like that you have 3 levels. I definitely would use the closed till I leave the hood as I usually don't turn on PSE till I am a couple blocks from my house. Can you program it so that it opens fully with PSE on/Sport mode and off otherwise, or you do have to use the remote/Homelink to control it.
The Flat6 site and their site mention an 'automatic' mode that can be programmed but I didn't really understand what that meant or how it worked. The Flat6 video focuses on programming the Homelink.
Old 08-02-2023, 07:20 AM
  #629
jhenson29
jhenson29's Avatar
No, you need a tune for that.
You have to use the remote (or homelink) for Cargraphic.
I think you can program what mode it starts in, but mine is just set to start in its last setting, which works well. If I wanted it loud or quiet where I was when I turned the car off, that’s usually how I want it when I turn the car back on later.
Old 08-02-2023, 07:37 AM
  #630
Guzzgreg
Guzzgreg's Avatar
Has anyone done this mod on a Targa. Getting under that rear hood is a pita. Not allot of room. That’s the only thing holding me back now.
Quick Reply: Cargraphic Valve Control Unit
