Porsche Dynamic Light System Plus (PDLS+)
Are these LED or Bi-xenon headlights?
The more expensive "matrix" is specific that they are LED headlights, but not sure about these.
Thanks!
Thanks!
You can activated PDLS+ in USA. In EU market we have a lot of US Porsche and most of them have activated PDLS+. If You have PIWIS....no problem, problem is only law
I don't know why in PR codes i have description about PDLS+ with second type of lamp
Every 911 comes with standard LED. The LED+ just has some extras:
- Dynamic Cornering Light - Dynamic cornering lights swivel the low beam in accordance with cornering characteristics, depending on the steering angle.
- Speed-Dependent Headlight Range Control - Speed-dependent headlight range control increases light distribution after 3,300 feet at 68 mph or higher, or immediately after 81 mph and above provided the steering wheel is not turned sharply.
- Sport Mode - Activated in Sport mode - allows for greater swivel angle depending on steering input
- High Beam Assistant - When a camera located inside the rear-view mirror detects the headlights of an oncoming vehicle, the high beams are automatically turned off at a distance of approximately 2,600 feet. If the taillights of a vehicle traveling in front are detected, the high beam is then turned off at a distance of approximately 1,300 feet
