992 Carrera T
And the 4.0L NA 9A2 Evo motor without the torque restriction of the Boxster/Cayman manual gearbox (309 ft-lbs) would result in more peak torque (~340 ft-lbs) than the last base Carrera with the 3.0 turbo motor (331 ft-lbs)...
That was it. And even the 991.1 was a 7 speed?
So today - if you want NA motor and 6 speed you need to pony up for a GT car. My point is Im not holding my breath for porsche to bring that NA motor & 6 speed manual formula back to the base or non-GT cars. I hope they do, but not so sure we’ll see it. Hopefully I am wrong.
So far the reviews about the 718 models with 9A2evo + 6 speed manual they make the same remark... gears are too long!
Question is:
I have not driven the 7-MT, is the feeling similar?
or in the 7-speed manual the initial gears also feel "too long" ?
Is confirmed that the upcoming manual base 992 Carrera will be a 7 speed MT.
a 7 speed shifting pattern for me does not seem "natural" as a 5 or 6 speed, but then again I have not driven it, I just wonder if this can be a better match for the 9A2evo ?
It is highly likely that the future 992.x Carrera T will keep the same transmission and same engine as the base Carrera + driver focused goodies from the "S" model + optional delete items. Which is the same strategy as in the 991 and 982(718)
Now also very important to keep in mind:
Engine selection in the Porsche range is not only based on hp+Tq is also based on CO2 emissions.
Base models MUST have lower CO2 emissions to keep them on the "base" or lower road-tax and emission tax. ( make them a bit more affordable in the EU markets )
The 9A2evo engine is already on a higher emission level (CO2) than the current 992 Carrera S engine... which means that it will be highly unlikely to be in the Base 992 Carrera, therefore highly unlikely to be in a future Carrera T. (PDK improves the CO2 by around 20gr/km)
Probably in a "special edition" of the 992.x we will see the 9A2evo to make an appearance. I cannot think of a specific model, It cannot be a "R" , it cannot be a "GTS", it cannot be a "T" ... options?
Or it will just remain for the 982 ? and 5th gen Boxster/Cayman. ?
TL;DR: My thoughts are 992 Carrera T will not have the 9A2evo due to emissions bracket in the EU countries
A 7 speed shouldn't have the same gearing issues, I'd imagine.
Interestingly, via at least one review I watched, it was insinuated that the 9A2evo doesn't sound as raucous as the 9A1 (not sure if anyone's heard the same or heard different?) but even if that were true, it's a 4.0 N/A flat six that revs to 8K, i.e will sound better than about anything else on the road, and especially once a freer flowing exhaust is put on it, will relentlessly send tingles down your spine.
https://www.youtube.com/watch?v=skYatVjFTlY
Even with the filters, you can hear how incredible it sounds on camera. Imagine in person....
I want that engine, BAD. It's EXACTLY what I've been asking Porsche for. A 4.0 N/A, less strung out than a GT3 engine, perfection. I salivate at the thought of it making it into 911's.
In the meantime- Im thoroughly enjoying the sound of my 991.2 T
https://www.youtube.com/watch?v=JUWu...ature=youtu.be
Get rid of the built-in Braun razorblade and add the 9A2 evo and you might be able to salvage the 992.
Conflicts with previous reports of porsche execs saying yes to a 992 Carrera T.
Sounds like the 4.0 in the 718 will not find its way to the 911. The only NASP 911 will be the GT3 according to this ^^^
Do we think we even see a 992 T?
https://www.roadandtrack.com/new-car...al-specs-cost/
no base model manuals, but if they make a 992 T - is it a “base model”
