FS: Vossen // Work Wheels for 991.2 (for factory tires)
Old 05-22-2017, 03:45 PM
rijowysock
rijowysock's Avatar
still available.
Old 05-22-2017, 04:16 PM
zx5go
zx5go's Avatar
These are never going to sell if STG doesn't get in here!
Old 06-02-2017, 03:49 AM
Jay V
Jay V's Avatar
Good deal!
Old 06-02-2017, 09:45 AM
Jenner
Jenner's Avatar
Possible to get Vossen to change the offset to fit my widebody?
Old 06-04-2017, 03:01 PM
rijowysock
rijowysock's Avatar
they took 4 months to be custom built... obviously they cannot be changed but you can easily get spacers made to accommodate your wider 991 (i have a guy i use that makes custom CNC'd hubcentric spacers)
Old 06-05-2017, 08:46 AM
Jenner
Jenner's Avatar
I'm under the impression that to make them fit, material would have to be removed from the wheel hub as they would stick out too far on the 991.2 widebody compared to stock offsets. Adding spacers would just make them stick out even more...
Old 06-05-2017, 12:04 PM
rijowysock
rijowysock's Avatar
if your fenders are wider, then these wheels would sit "in" versus normal fenders.. meaning a spacer would correct the problem.
i do not know the offsets for 4S vehicles.. but i don't believe it's much of a difference, maybe 10-15mm...
many people have put narrowbody wheels on a AWD widebody chassis... spacer size varies for the wheel used.
shaving the hub would be if you put widebody wheels on a narrow body car (the fenders are smaller, meaning wheel goes out more compared to fender)
Old 06-05-2017, 12:20 PM
Jenner
Jenner's Avatar
What matters is the factory wheel offset and the new wheel offset.
http://www.1010tires.com/Tools/Wheel-Offset-Calculator#
The wheel widths are the same with as my stock Turbo wheels. The problem is your front has 40 offset when I need a wheel with 49. That does not require a spacer as you suggest and I'm not interested in machining down a wheel hub, nor do I want the front tire sticking out from the fender as I already have enough rocks hitting my doors and the wide body fenders. Make sense?
Old 06-05-2017, 01:20 PM
rijowysock
rijowysock's Avatar
both our factory fronts are same 8.5+49, i ordered the 9mm difference on purpose as the stock wheels "sink in" to the fender too much for my liking
Old 06-13-2017, 10:08 PM
rijowysock
rijowysock's Avatar
bump
Old 06-18-2017, 10:50 PM
rijowysock
rijowysock's Avatar
bump
Old 06-20-2017, 03:23 PM
rijowysock
rijowysock's Avatar
sold
Quick Reply: FS: Vossen // Work Wheels for 991.2 (for factory tires)
