Ceramic Paint Coating -
#46
#47
Coatings allow you avoid having to constantly clay, polish and reapply wax. Aside from saving you a ton of time, you're touching the car way less, which means less chance for adding marks to the car. Also, I don't care how good your wax is, it will degrade and when you go to wash your car, it will never have the shedding properties that a nano coating does.
I love the coating because I love fact that I don't have to waste all that time claying and polishing my car, and I can wash and dry my car in less than 15 minutes. And when I'm done it looks as good as a car that someone just spent hours detailing. Every time. My C2S OptiCoat is going on 2 years old and it still repels everything like the day it was applied.
#48
I agree with you on all points, except that a wax "will never have the shedding properties that a nano coating does". A well waxed/sealed car is going to be the same as a nano coat in terms of protection and hydrophobic properties. It just takes more work to maintain those properties.
#49
just get a good installer too. I went with someone that friends recommended. They did my wife's Z4 summer before last, and the 991 I no longer have also. Her car has seen about 300 miles since then and been washed 3 times, and last time I washed it, the water didn't even bead on the hood. Not real impressed. On my current 991, I did Pinnacles new nano coating and its holding up great after a year, but I think its time to reapply now that spring is here.
btw, anyone want a cherry 2010 Z4 that looks like it just rolled off the showroom floor?
#50
I don't know about 'ceramic' coatings or what that really means, but OptiCoat Pro Plus does not require sanding to remove. That said, if you're repainting an entire panel of a car, you're probably gonna sand the clear coat off first anyway.
And OP, I can agree with LexVan that OptiCoat Pro Plus is awesome. But no way you're getting it done for $600. I understand it just went up to $1,100, and that doesn't include paint correction.
#51
#53
The most important part is the person doing the detailing. Wash, clay bar, paint correction, and a ceramic coating is close to a full-day job, so $600 seems too inexpensive for a top-notch detailer.
I had Opti/Xpel on my S4. I made an appointment for my 911 (wash, clay bar, paint correction, and a ceramic coating on car/wheels), and prices range from $795 - $995, depending on the coating.
Do extensive research on the detailer before you hand him the keys, and do not go through your dealer.
#54
I wrote a few articles to educate owners about the subjects discussed in this thread.
There are concerns with what causes defects, how to minimize those surface defects, how coatings are supposed to perform, what is required on your end to get the most value and expectations. If you find yourself a bit lost on those topics, take the time to read these pieces and I think you'll come away much better prepared to make your own choices with coatings.
The Paint Coating Triangle: A Necessity for Owner Satisfation - Detailed Designs Auto Spa (not to be confused with the "conjoined triangles of success"...)
What causes swirl marks and other defects in modern car paint? -The Clear Bra Installation Specialists of Atlanta-
#55
I have Xpel on all my cars. 4 years on an RS5 that sat outside in direct Florida sun all day. Only a slight color shift when we traded the car in. It would have been vovered by xpel if I thought it was worth replacing yet. White car (Suzuka grey) On my R8 now almost 5 years and no waxing the Xpel looks still like new. Car is garaged. Also near white with the Suzuka color. My Porsche 2 years and fine (again not waxed) and my 50K daily driver. I have each car with a different coating but all have worked great...wheels really worth doing. It in my experience has provided protection against the swirls. Paint looks good on all after multiple years. I had my R8 re paint corrected and recoated after 4 years. I did full paint correction then coating on parts not getting the film. On one car we did a full coating but the film then had a hard time sticking in complex spots so skipped that part knowing the film is doing the work anyway. As said the skill of the paint correction is THE most important thing.
#56
