How to remove overhead console?
Anyone have pictures or can offer directions how to remove the overhead console? I've developed a slight vibration resonance over cobblestone roads that I've isolated to this part and I want to apply some foam tape to try to eliminate it.
There are two clips that you need to push in with a credit card in order to release it - one on the passenger side and the other on driver side.
Thank you!
I have a rear facing camera in conjunction with my front facing and I was curious if i can fish the cable through from the front to the back after removing that overhead console
What I did to install my rear camera was to run the wire along the front headliner, under the A pillar, and along the door weatherstripping. Followed the weatherstripping down to the door sill and then snaked it along the rear seat panel crevices to the back. You can then run the wire up along the rear window liner and connect to rear camera, wherever you decide to mount it.
Hope this helps.
Don't know, never tried it. May be possible, but doubt it would be easy. Probably need to put a snake through rear headliner and hope there are no obstructions on its was to the overhead.
Hope this helps.
Hope this helps.
thanks
Update to this: the slight creak may not have been coming from this at all, but instead where the passenger side sun visor clips into the headliner stay. Put small felt circle in the stay, and the creak is gone.
