Manual T - launch control
I haven't done this on the 911 but I have on other cars. Generally speaking, you should turn off traction control and just drop the clutch at 4,000rpms. The rear tires will spin which takes some of the strain off the driveline and prevents bogging down. I don't think there's any effective way to feather the clutch with your left foot when launching. The traditional method is to drop the clutch.
The only alternative method of getting the engine up to boost during a maximum launch is to slip the clutch, which is very hard on the clutch and also very difficult to execute with the perfect degree of slip.
Presumably Porsche has implemented this 4000-rpm limitation because the driveline won't withstand higher rpm clutch drops, at least not for long.
Interestingly, older Porsche had no such limitations, including the 993 Turbos, which would gloriously spin all four wheels when blasting off with a high-rpm clutch drop.
A clutch drop on a MT is like a death-wish for your clutch. I have done 8 Launch controls in a GT3 with PDK at PDE-Atlanta. I should apologize to the poor person who inherits that car. I would NEVER do that in my MT GTS. Who needs it?
I also tried a .2 MT at Atlanta and the instructor had no worries about burning out the clutch on a fast takeoff from a standing start. Consider that these cars get hammered every day, 5 days a week for 6 months before ending up on a Dealers lot as a CPO.
Does the MT being a duel clutch (same as the PDK) make a difference?
It's the "wet" part that makes all the difference because the clutch fluid is circulated and actively cooled. That allows it to be slipped during the launch control procedure without overheating the clutch plates.
When you slip the dry clutch plates in a manual transmission, there is no means for removing the heat generated and that's what can cause the damage. That's why dropping the clutch and slipping your tires, while a violent procedure, is easier on the clutch, so long as nothing else lets go in the driveline.
