991.2 Carrera IPD Plenum testing results
#31
A 20 hp/tq gain with a simple plenum replacement sounds like "low-hanging fruit". You'd think Porsche would have thought of this "laminar flow trick" all on their own, or at least checked it out. Maybe they did, and found no benefit. Are we really supposed to believe that Porsche designs these beautiful engines, but has absolutely no clue when it comes to designing a plenum? Sorry, just a bit skeptical...
Manufacturers almost always leave something on the table for the next generation or refreshed models... Think 992.
I don't think these Porsche Engineers go ***** deep into extracting as much as possible on every engine.
#33
#34
Originally Posted by 1analguy
I don't get this analogy. Are you saying that Porsche made the 991 engines too big just so they could shrink them down and plaster on some turbos for the 992?
#35
I wanted to re-bump this thread.
Anyone else install the plenum and have any insight? I am interested in putting on my GTS, but Im not completely convinced its going to make that much difference and the fitment/clearance seems to be a commonly complained about issue.
Im running COBB Stg.1, AWE Sport cats and a BMC filter on my GTS. Im assuming there should be more gains now that I am tuned, but maybe theres a place to better spend the money?
#36
Can you give more insight on your tune? Been patiently waiting for you to post something but I didn't want to ask.
I have same mods as you add headers. I'm eventually gonna buy the plenum.. Through PM I was told by another member that the IPD made a difference at WOT.
#37
I asked two guys about doing the plenum before I pulled my ECU for the tune as that was the time to do it. Both guys said don't bother, don't waste your money. One of them, who will remain nameless, actually said that they tested the plenum at COBB on a dyno and there was no discernible improvement. The other guy (also a hot rodder) said that the dimples and design should have zero effect on HP. He actually said "if fuel was going through it I would consider it but, all it does is flow AIR". He also said that the BMC filter should improve airflow more than a plenum could.
I am thinking that maybe the guy who was pulling on guys with the plenum that he wasn't pulling on before, might have also changed the air filter at the same time but, I cant recall.
I am all for cheap HP and I had the OEM plenum on the floor in front of me when I did the ECU pull and Air Filter swap and after looking at it I came to the conclusion not to do it. Believe me I wanted to and the labor was ZERO at that point. I just decided it wasn't proven enough to bother.
If real proof shows it to provide significant dyno gains I would certainly reconsider..
#38
4.0 says it gave him enough gains to pull on cars he wasn't pulling on before.. Its only 800 bucks and you're running a BMC filter anyway.. If you're not sold on it put it towards some intercoolers and comfortably run stage 2/3.
#39
I haven't done the BMC as yet. I was waiting for the full carbon box to come out by aFe? I have seen dyno's of the IPD Plenum and whilst they didn't add anything up top, they did add some delta in the mid range.
So I figure combined with Headers for top end and a tune, they would work in nicely. I roll race frequently. There were a couple of cars that just beat me prior to the IPD, but that was enough to turn the tables and have me in front. So I am a believer it did something. But its not going to be like a Stage 1 tune lol.
I am more sceptical that the BMC would do anything other than Sound. Its great that 991 has MAP and not MAF, so no oil possibility of oiled filters fouling whats not there.
#40
I wonder if IPD will do the Y pipe for the C, CS and GTS like they did for the TURBO.
#41
That cannot be good for flow. The air hits it square on and bounces backwards stalling further air coming in. Blind freddy can see that. The IPD design, is a Y. It channels the air to either side without any blockage or back pressure or back flow. As for the dimples, I gather all three of you don't play golf? It will definitely provide smoother better flow.
Now with all of this said, will that amount to much HP? Probably not much on a fully stock engine, but as you mod, it will have greater and greater effect. Similarly like headers. On Stock tune, won't do much, but as you tune more aggressively, it does more.
Changing an AIR filter will not have as much effect as removing a Dead end T intersection from the path of air. An engine is little more than an air pump. You want uninterrupted air flow as much as possible.
As with most air flow mods, they don't usually show much sitting stationary on a dyno. But when the car is moving fast, the better they perform. Such a cheap mod and you want to see SIGNIFICANT gains on a dyno. Doubt that will happen. But they show a dyno with some nice mid range improvement. Every bit helps, its the sum of the parts. Its also a fit once and forget about it, it's there for life. No maintenance. Set and forget and enjoy better flow forever. No moving parts, nothing to lube or tighten or clean or change. Set and forget. It was a no brainier for me. But I am a no stone unturned type of guy.
#42
Based on what I can see from the pictures - it appears the design attempts to limit turbulence in the boundary layer through the splitter. This is actually a pretty common approach in engine intake airflow design in various applications (aviation engines especially) and depending on specific factors of the engine can significantly reduce energy loss, increase mass transport, and reduce pressure-drop through the intake. Easy way to tell would be to pull data on the MAF sensor from the CAN bus on a car before / after the install. More mass airflow = more power. The ECU should adjust the charge based data from the MAF. I suspect (but don't know) that the 9A2 probably also has a intake ambient pressure sensor - which should also verify effectiveness. Turbos benefit more, as the pressure drop across the plenum is lower for laminar flow than turbulent flow, and thus the pre/post compression pressures will be higher.
Great engineering-driven upgrade!
cheers!
cheers!
#44
