Question for you battery charger folk...
I decided I wanted to bolt on a direct connector to the battery terminals for my charger.
1. The bolt on the terminal is flared at the end as if they really don't want you to remove the nut. I tried to force it past but feared I would damage it. What have others of you done regarding the charger terminals? I assume I have to bolt it directly to the terminal and not on a nearby ground. (?)
2. And that warning graphic near the terminal looks ominous. Do I take that to mean don't do what I am thinking of doing?
The following 2 users liked this post by 911Monte:
Fullyield (02-19-2021),
maschinetheist (02-18-2021)
1+ for Monte. Cut the ring to make it a spade. Don't mess with the car. And don't worry about the jumper camble warning--that's to avoid sparks with cables, not a secure wired connection to a charger.
I've been meaning to do this. I've been using the passenger footwell 12v socket, which is inconvenient.
For a moment I thought the second photo had some sort of strain relief for the pigtail, and then I realized what I was seeing was the cap for the connector lying loose. I don't recognize the connector - it's not the SAE connector that the Battery Tender uses.
This looks like an improvement from the footwell socket...but only by half. Because you still have to have the hood open (or closed and crimping the wire) to use it. That's the same thing that bothers me about the passenger side footwell plug: you either wind up shutting the cord against the door or window (which you can obviously crack open). The dealer said "not to worry" and it's fine to shut the door on the cord but it just seems kinda fraught to me.
Has anyone routed the pigtail so you can plug the car in from, say, the front bumper area? Clean install that you plug into without a hood, door, or window in the way?
I use Porsche nuts route as well. The only problem I have is what to do with the cord with the car cover on. The best I can figure is to wrap it in a microfiber towel so it doesn't scratch against the paint.
That's a tough one. Only suggestion I would have is to cut a small slit in the cover and put the cord through it. Don't know if you want to do that, but might be easier than a bunch of microfiber towels.
Inspired by you clever folks, I ended up doing a variation of the theme. I routed the charger cord to a nice natural pocket of space that lies beneath the hood damper (shock). I can easily reach into the area with the hood closed and pull out a few inches to charge the battery. No mods or cutting necessary. Super fast and easy to charge her up now!
A couple shots of it laying in the recessed pocket at the base of the damper. You can make out the shiny double cord in the shadows.
I can reach in blindly with my finger and pull on the loop of the charger cord even with the hood closed.
It hooks up easily.
It hooks up easily.
I actually did this first for my 993 where the interior cigarette socket connection is finicky and unreliable. I like how it turned out and applied the same solution to the 991. I like it.
Nice idea Brad. Great that you can get to the cord without opening the frunk. I like it.
