Door panel top detaching ?
#106
This issue seems to be specific to the 991. I have had a 987 Boxster and currently a 958 Cayenne. Neither of those cars had/has interior defects. Actually I feel the Cayenne is the most solidly build car I ever owned. Door panels don't move at all.
A search of the 981 forum did not reveal a posting about door panels. Looks like there is something on the design and/or installation that causes the warping. If it is a continuous issue, then Porsche should do some re-engineering or have a band-aid solution to stop future warps. Can't expect owners to keep buying new panels once warranty and/or goodwill stops.
#108
There are 2 long threads on this on planet-9. The 981s have identical door panels to the 991 and are having the same panel separation. No full leather door panels on that forum have had this issue to my knowledge, but 981s also have a much smaller sample size of full leather interiors.
#109
I call BS on what the sales rep told you.....
warranty paid parts STILL carries the same warranty (1 or 2 years i forgot)
I am sure of that because my HPFP went out and was replaced under recall/warranty by Porsche in my 987.2. the HPFP went out AGAIN within 12 mos and it was all covered under the parts warranty (parts and labor, plus towing etc.)
#110
I suggest everyone file a complaint on the door panels to the https://www.nhtsa.gov
This is safety related since it involves the airbag.
I KEEP SEEING POSTS ON THE PANEL DETACHING OR COMING UNGLUED. THAT IS NOT THE CASE.
THEY ARE NOT GLUED SO DO NOT TRY TO GLUE IT BACK DOWN OR YOU RISK THE AIRBAG NOT DEPLOYING CORRECTLY.
#111
#112
Were it says "airbag" isn't where the bag is it's at the top back of the card.
#113
I wonder if the plastic piece that the dealer proposes gluing the warped part of the panel to is designed to displace when the airbag deploys. Seems odd that the panel would not be glued to the plastic from the factory - I was under the impression this failure occurs because of adhesion failure.
#114
I have my own pics of my 997 crash which I posted earlier showing the air bag deployment and I found these on the Wrecked Exotics with only one car showing deployment from the door panel and not from the gap between the panel and the window.
The only pic I found with the side airbag coming out of the door not at the window.
#116
Not something that usually just “pops” up but rather, slowly progresses. If yours came on suddenly, might be something else? Also, were your panels leather? Seems to been next to nonexistent on the leather panels, for some reason...
#119
I ended up finding a '13 with the leather option, and the panels are flawless with absolutely no signs that they will ever bow up (at least not yet).
#120
Mine is not leather. It's possible it come on more gradually and I didn't notice it; it is on the passenger side, and my wife noticed it when she got in. She might not have been in the car for the past few weeks or so.
