Door panel top detaching ?
#166
Received 4,387 Likes
It's an expensive fix. A new door panel from the dealer is around $ 3,300 per each. If one side has failed, the other won't be far behind. Other than that, you can try some glue yourself, its caused by the side air bag design / heat / time. I have replaced mine under CPO warranty on my 2014.
#167
Also keep in mind that the prices quoted do not take into consideration if it’s a leather interior or not (although, at least from what I’ve read, leather interiors warping don’t seem as common - but that could just be b/c of the smaller sample size). Finally, be careful about believing this is a “quick fix” - there are airbags in the doors. I don’t profess to be an expert by any means but I would always wonder whether or not whatever solution I used was “too strong” and would interfere with the deployment of the airbag in an emergency. With a factory replacement I had more piece of mind. If it were me, I’d ask for at least $5k off.
#169
You’re past the window for a courtesy repair or CPO I imagine so yeah, $3000 and change for a basic panel. I’d deduct that plus $1000 more for the seller being a liar :-)
well it is quick and easy if you drop it off at the dealer and sign a check... but it is very common and cosmetic only. Kinda annoying we don’t have an aftermarket repair solution by now.
#170
My dealer just ordered both panels under CPO and hope to request Porsche NA that selling Porsche dealer be changed back for selling a car as CPO WITH warped panels
Porsche needs to fix these on all cars.
#171
Seller is contacting someone at Porsche in Dallas to see what the fix will be. I told him it has to be done 'right' for us to do a deal, or gotta knock off $3500 for me to have it done. He didn't say no. What a crazy thing to go wrong.
#172
I tried fixing myself and one door worked the other one didn't. So i'm looking on local and fleabay sites if anything comes up on the cheaper side. For now driving as is.
#173
I combed through the last couple of pages, but does this issue affect all models? I'm the new owner of a gently used 2014 C2S. It's just out of CPO and this thread is making my knees weak already.
#174
If your car has leather option you'll be fine. It seems warping only affects on plastic ones. It is very unfortunate situation and pricing on panel is just ridiculous. Maybe time for class action by owners?
#177
Well ****. My doors are non-leather. Just a matter of time now before they separate? Someone posted a link to a FB group who is starting a class action lawsuit.
#178
Guys, one thing to keep in mind is that even if they're replaced, the new ones will eventually do the same thing. What we really need is a workaround hack job repair that we can do ourselves
Mine are warped, but fortunately, they're not that bad. I do expect them to get worse with time, though.
#179
Guys, one thing to keep in mind is that even if they're replaced, the new ones will eventually do the same thing. What we really need is a workaround hack job repair that we can do ourselves Mine are warped, but fortunately, they're not that bad. I do expect them to get worse with time, though.
Isn't the "home" fix a liability issue, though, given the airbags deployment path ? This one is going to be tricky. Maybe we need to start jamming a stick between the door panel and the roof and store the car that way ;-) I'll take that over an IMS bearing though.
#180
What's the warranty on replacement parts? 4 years? No way they won't start warping again in that amount of time, just make Porsche keep replacing them over and over every 3.9 years.
