Wheel Hanging Tool
Need them for Center Locks too
I use a long bar, but thinking of getting a multiplier to keep in the car just in case I need it on the road.
I too found it was easier to lift and locate the wheel on the center hub. No problem rotating the wheel to line up the bolt holes. It took more time and effort to maneuver the wheel lug holes over the guides.
_____________
2014 991 TT
2013 958 CD
_____________
2014 991 TT
2013 958 CD
absolutely agree w prev comments of " two better than one better than none " esp since they are so inexpensive and take up little space in tool kit
with one , the wheel still swings like a pendulum making seating the first bolt with potential cross-threading possible due to side loading
with two , placed at 10 and 2 , a piece of cake !
. . . and before I forget, NEVER use the wheel end cap removal tool that comes with the car. If you do, it is guaranteed to ruin your end cap -- even if you are very careful. Instead use a plastic trim tool or a small taped screwdriver (those stupid caps are expensive!)
What I have seen in my frunk, is the CL nut to square drive socket adpator and the little clip thingie to remove the cap. The removal clip is metal, and I think that is what Porsche_nuts says is bad. I do not recall seeing any wheel alignment device in my 991.2?
The extra step is well worth getting the weight off my arms trying to line up the bolt holes.
Yesterday I just orientated the wheel with the security bolt at 12 o'clock and removed that one completely and inserted the tool then removed the rest of the bolts. Installed the other wheel and the bolt holes lined up lickety-split. No cussing.
