Dealer forgot to do Spark Plugs for 40k Service
I have seen this happen a few times with dealers, most people don't know better. At my 20k service the dealer didn't do the interior cabin filters (one in the frunk and one under the dash). They SA argued with me that it wasn't included in their service, even though prior to the work they agreed that the service includes everything in the manual.
The crazy thing is that he refused to make it right. I made a claim on my Amex card that I had used to pay for the service and got the money refunded. $700+ and a lost customer for a few dollars in air filters? I have no idea what these dealers are thinking.
But cabin filters? I mean isn't that literally a 15min job?
Received 5,388 Likes
Originally Posted by ltdodge
the biggest question is WHY change plugs at 40K miles??? that's an overkill, plugs should last 100K miles
My car goes in for new plugs Wednesday at about 43,000 miles. Having the 40k service done.
Freddie Two Bs (04-16-2020)
But, it's not easy to check the wear of spark plugs. If you go through the trouble to check and test them, you might as well just change them. They cost $5-6 each if you get Bosch.
Make sure they did these 40K service items as well:
- Engine air filters (x2)
- Cabin air filters (x2)
- Brake fluid flush
- Oil and filter change (of course)
BTW, plugs are suggested at 40K miles *OR* 4 years, whichever is first. I just changed mine at 19K miles because it has been 4 years.
- Brake fluid flush
Of course the plugs could be removed after five years and then coated with anti-seize compound, but if you have the plug out why not replace it. It's not that difficult to take out threads in the head, while removing a seized plug. On a Porsche I would never go longer than five years without changing plugs, regardless of the mileage.
i did change my plugs at 40K and they looked perfectly fine, not much carbon in them and the gap looked fine. all im saying is the plugs should be able to go longer than 40K unless its a garage queen and you have more years than miles. im already at 65K miles on my car.
A couple weeks ago I pulled plugs from a 997.2 with the 9A1 engine with a friend. The car has a little less than 40k miles but the car is over 8 years old. No issues unscrewing the plug. We "think" the car runs and idles a little smoother. However, the difference is/was so minor, the plugs could have probably lasted another 8 years.. The plugs didn't look too bad either, they just looked used.
Update: Dealer admitted fault and will pay for the spark plugs to be replaced. I'm happy I don't have to fight them, but I wonder how often they 'forget' to do service items on these CPO cars.
Next Question: The car is driving a little rough and the fuel efficiency is a bit lower than normal.
Is it safe to drive on these old plugs for another couple days until I can get it in on Monday? I don't want to damage the car.
Thanks guys!
Thanks guys!
During the CPO, they documented completion of the 30k mile service and would not need anything until next 10k service.
In reviewing all the paperwork/service records and CPO sheet, i noticed there was no mention of spark plug (8 double tipped platinum plugs for the beast).
Now mind you, this is one of the largest midwest dealers. When confronted, they simply assumed that all Cayennes had plugs done at 40k, which is correct if it was NOT a Twin Turbo V8.
They changed the plugs quickly and updated the Carfax report. Ticked me off because i know how many times this provably occurs and people don't catch them. On the flip side, being one of the highest volume dealers, increases the potential for errors.
Drink the cool aid If you drink the Kool-Aid then you’re going to pay the price. Most
Glad to hear that the dealership is paying for the plug job. I too have had bad experiences with stealerships in the past. Years ago, I was looking at a CPO vehicle. Long story short, every thing on their CPO checklist was pencil whipped. A common scam that some stealerships do is they use a turkey baster to drain the master cylinder and refill it with fresh brake fluid, and call it a brake flush. Air filters, coolant flush, and transmission flush are few others. Buyer beware. As my old man used to say, DIY if you want it done right. Or, find a reputable Indy shop.
I had dealer install a winter wheel set up on a BMW last year.
I had to remove 1 wheel mid winter due to a bubble on the tire.
All of the lug nuts were slightly rounded off and all of the lug nuts had minimal tightness.
The tech either used the wring size socket, clearly used a impact wrench, and I doubt that they used a torque wrench.
Best option - service your own car if you can, other wise find a quality independent shop who takes pride in their work.
Not all dealer techs are poor - but you need to check for the quality of their work.
A MB that I recently sold, need a oil service.
I went to the dealer because the oil change light needed a reset.
The dealer was 1 hour away, had to leave the car.
I picked up the car and when i was almost home - the oil level light went on.
It needed a quart.
I suspect they changed the oil when the motor was cold.
With dealer service - it's buyer beware, and more expensive to boot.
It needed a quart.
