3.0 Powerkit the exact same as GTS?
Would adding the powerkit to a 991.2S give you the exact same engine as the new GTS?
The powerkit takes HP to 450. But it doesn't say anything about torque. Is it identical to the GTS torque figure of 405? I assume so but would be nice to get confirmed.
And, has anyone seen the torque curve for the GTS and/or powerkit. The S produces 368 from 1700-5000. The GTS produces 405 starting at 2150. I'd like to see the whole curve for that, particularly for below 2150.
With the larger turbos, wouldn't there be more lag? Wonder how noticeable it is.
Finally, does anyone know about the timing/availability for the powerkit?
