Serious loss of traction and instability with new front tyres
Old 12-12-2016, 03:22 PM
Zkalra
Zkalra's Avatar
Default Serious loss of traction and instability with new front tyres
Hi guys,
Having a major issue - So I have fairly new rear tyres about 9 months old and say 3-4K kms, and since the front ones were worn I changed to brand new p zeroes of the correct size and spec. Both front and rear are matching. So now I have brand new from ones and older rear ones. Since the change I'm feeling the car to be fairly unstable especially at speed. I get a general feeling of understeer when I take a corner which quickly transitions into oversteer and the rear loses traction. Moreover the sense of stability is entirely missing from the vehicle. This never used to happen before and in fact the legendary Porsche traction has never let me down. Could this be due to different wear in the front and rear tyres?
EDIT - 2012 991 Carrera S, PDK, sports Chrono, all options ticked.
Old 12-12-2016, 03:30 PM
LexVan
LexVan's Avatar
Received 5,387 Likes on 2,509 Posts
Check your tire pressures. Give it a couple hundred miles for the new tires to scrub in, and wear off the mold release. How many miles so far?
Old 12-12-2016, 04:28 PM
bright_medal
bright_medal's Avatar
In my opinion, I don't think it has anything to do with the difference in wear between your front and rears.
I agree eith Lexvan. I'd suggest you communicate to whoever you bought the tires from right away and then give it a short while to see if the tires break-in. It's rare, but I had the same thing happen to me (on a different car). I got a new set of tires, immediately felt unsafe, replaced them, and everything was fine thereafter. Bad set of tires. However, I think giving them a short while is worthwhile unless your tire shop would just rather replace them rather than taking liability which happened to me. Good luck!
Old 12-12-2016, 05:53 PM
Needsdecaf
Needsdecaf's Avatar
Received 2,524 Likes on 1,571 Posts
They installed right side out? Serious with this question.
Check pressures.
When I bought my car, the rears had about 1,000 miles on them, and the fronts were new. Stable as the Rock of Gibraltar.
Old 12-12-2016, 06:27 PM
chuckbdc
chuckbdc's Avatar
Brand new tires are always more "slippery" than worn tires. They will get better as they wear.
But the advice to check tire pressure and make sure they were correctly installed is all good.
Note too that you should have the fronts and rears within about 5 lbs and to take in to account the cold weather.
Old 12-12-2016, 11:27 PM
StormRune
StormRune's Avatar
Chuck brings up an excellent point with the weather comment, as well as LexVan and others with the the tire pressure and scrub-in comments. Make sure you are using Partial Load pressures, Comfort setting if you wish, but not Full Load.
It's not clear where you live or what the temperatures are in your area. The P-Zeros are high performance summer tires. Once the temperatures get into the 40's, or especially if it drops near 40 or under, the tires get pretty hard and much more slippery. Could this have been a factor? Or is it warm where you are?
Old 12-12-2016, 11:52 PM
Zkalra
Zkalra's Avatar
Hi, where I live the temperature is round 21 C during the day and 10-12 C during late evening. I'm talking about day time driving so temps cannot be the cause.
The tyre pressures are set at comfort and is perfect. 33 front 35 rear.
The tyres are installed correctly too. Done about 800 kms on them so far
So I'm totally confused as to what can be causing this.
Old 12-13-2016, 04:02 AM
randr
randr's Avatar
Are the tires the same specification e.g. N0 or N1 P-Zero
Old 12-13-2016, 06:56 AM
LexVan
LexVan's Avatar
The next consideration is alignment.
Old 12-13-2016, 10:10 AM
Zkalra
Zkalra's Avatar
Hi, the tyres are the same spec exactly. N0.
Old 12-13-2016, 11:32 AM
teambell
teambell's Avatar
Check lug nuts are properly installed and torqued to spec. If they are, return to tire shop and get their assistance.
Old 12-13-2016, 01:57 PM
Zkalra
Zkalra's Avatar
Lug nuts are also fine
Quick Reply: Serious loss of traction and instability with new front tyres
