Auto Lowering mirror during reverse not woeking
Old 12-11-2016, 12:29 PM
911Enthusiast
911Enthusiast's Avatar
Default Auto Lowering mirror during reverse not woeking
Gurus,
Recently, I started noticing on 991.1 GTS that my left or right mirror (depending on which is selected) no longer auto-tilts during reverse. I have tried:
- resetting to factory settings, and reselecting auto-lowering option in PCM
- manually changing mirror angle (which works)
Any other suggestions on what to check? Or is it time to take it into the shop?
Old 12-11-2016, 12:51 PM
Homeles
Homeles's Avatar
Did u store ur settings after the changes?
Old 12-11-2016, 01:11 PM
911Enthusiast
I did save the setting
Old 12-11-2016, 01:13 PM
Al.Fresco
Al.Fresco's Avatar
Using a different key by any chance? Have seen posts of that doing weird things to different settings.
Old 12-11-2016, 01:23 PM
911Enthusiast
Good point! Alas, it's the same key.
Old 12-11-2016, 02:06 PM
Leader
Leader's Avatar
I believe the mirror adjustment switch has to be clicked over to the passenger's side mirror position for the "reverse dip" to work.
Old 12-11-2016, 02:16 PM
Pmorritt
Pmorritt's Avatar
^^^. What he said.
Old 12-11-2016, 02:17 PM
Porsche_nuts
Porsche_nuts's Avatar
Received 1,117 Likes on 666 Posts
This ^^^
Old 12-11-2016, 04:12 PM
911Enthusiast
Hahaha... yes, it's dipped... changing it to right or left has affect... it used to work; now it doesn't sounds like a software bug?
Old 12-11-2016, 07:29 PM
StormRune
StormRune's Avatar
So let's take it fully step by step again. I know you've done several of these, but I'm not sure you've done all of them correctly. It's worth a shot.
1) Under Vehicle Menu, Settings, Lights & Visibility, Reverse Options, Lower Mirror: Confirm that "Mirror is lowered" is selected
2) Put the car in reverse, and while you have the car in reverse, lower the right mirror to the position you want memorized (this is adjustable, it remembers where you've left it up/down/left/right).
3) Leave the right mirror selected.
4) Hit the Set and Number you want to associate this saved setting with, or Set and 3 if you want it to be associated with that particular key.
Now starting with the car not in reverse, when you put the car in reverse, the mirror should return to the position you left it in when reverse was last engaged.
Note that if you don't lower the mirror into the position you want memorized while the car is in reverse, it ends up memorizing the normal position. I think when I last changed the memorized reverse position to be a little higher, I hit the "Set" memory buttons while the car was still in reverse with the mirror in position, so I'm 100% sure it should work that way at least.
The following 3 users liked this post by StormRune:
awfilms (04-28-2020), JacobQ (11-23-2022), Jimmyk79 (01-07-2021)
Old 12-11-2016, 07:52 PM
911Enthusiast
Thank you for the detailed steps! I haven't changed the "set" settings in a while. Perhaps hitting reset on PCM controls reset it to non-lowered position (as described above). I'll execute the mentioned steps tomorrow. Keeping my fingers crossed.
Old 12-12-2016, 05:41 PM
911Enthusiast
Storm, it worked! Now I have a new problem in that the lowered mirror position doesn't reset to normal mode after shifting from R-->D. Same happens from R-->P as well. Turning the car off leads to returning to normal position. After that, Putting in R leads to lowering of passenger side mirror. But, subsequent shifts to any other gear don't result in a return to normal position (waited over a min after gear change to see result)
Old 12-12-2016, 05:51 PM
Al.Fresco
Al.Fresco's Avatar
Seems I read somewhere its speed triggered....like after you slap it back in drive and get up to X speed, it will flip up. Give that a shot.
JacobQ (11-23-2022)
Old 12-12-2016, 10:29 PM
StormRune
StormRune's Avatar
That's right. Did you drive forward? (I didn't think to put that in the directions). It stays down until it thinks you are done doing your parking maneuver, so until you drive away it won't raise up as long as the switch stays set to the right mirror.
However, it will come up immediately if you switch the control back to the left mirror. (Sometimes it lowers when I'd rather have it stay up, so to disable the lowering I'll select the left mirror, even while still backing).
JacobQ (11-23-2022)
Old 12-14-2016, 05:21 PM
911Enthusiast
Oddly enough, the lowered mirror does restore to normal position once speed >20mph.
I recall that prior to "reset", mirror would come back to normal at the time of gear shift from R to either P or D. Not sure how the previous owner managed to achieve that.
JacobQ (11-23-2022)
Quick Reply: Auto Lowering mirror during reverse not woeking
