PADM Failure Again
#136
Nice!
The PADM message has been on a few days. Went for a nice drive this morning and again the PADM message was on at start-up. About 30 minutes into the drive it went away. Drove on for several hours with multiple shut-downs and start-ups and the message has stayed off.
Maybe it corrected itself, though I expect it to come back on at some point.
#137
Hope it clears, @Babakazoo . Mine never did (‘15 991.1 Targa 4S). Replaced my PADM mounts with Rennline’s semi-solid mounts. Cold here in Detroit, so have yet to drive it and thus I can’t offer feedback. Here’s the new mount next to the old.
The failed part # was 991.375.059.08. Current part is x.11… multiple revisions which tells me they are still trying to get it right.
#138
https://rennlist.com/forums/997-turbo-forum/1208299-semi-solid-engine-mounts.html
Copy and paste
Was looking at semi solid engine mounts (65 -75 shores) for 2008 car, but my tuner has discouraged. Says it can trigger knock sensors and pull timing.
65 shores would be the softest of semi-solids and I thought knock sensors would only trigger with the stiffer semi solids or solid mounts
#139
I read about the knock sensor concerns, too. I believe, but can't confirm, that issue is seen more in the 997 era cars (which it sounds like you have). The PADM units in the 991 and 992 era vehicles are failing but I have not heard of the knock sensor concern with those vehicles. As an alt, one could also look at Porsche's non-PADM factory mount.
James88 (03-24-2024)
#141
I had a PADM failure in non-sport mode (just highway driving). I believe the two PADM mounts are always powered, but just "softer" mode unless in Sport Plus.
#143
I have a PIWIS II, I believe you would need to disable Sport Chrono to turn off the engine mounts. Which would be less than ideal for people with SC. The DSC option might be the easiest. I can do more digging around my PIWIS to see if we can turn off active engine mounts.
