Door rattles when Bose system plays music with Bass
Hi all,
I searched the forum for this but did not see a similar post.
As topic says, when I play music with high bass the door rattles and there is distortion of the sound. Almost like something is loose (a screw or something?). This is confirmed as when I pause the music it goes away. Not noted on the passenger door. I'm taking her in in 2 weeks (which is next available appointment) - just fishing for ideas.
thanks
15 GTS C2
thanks
15 GTS C2
Same problem, but it didn't require high volume or heavy bass. Before I took it in I experimented because I wanted to be able to amply demonstrate it. I could always get it to buzz on bass notes when I tuned Sirius to the smooth jazz station -- it's called Watercolors and it's 66. Even at low, conversational volume it would rattle the driver's door and not the pax side.
So I brought it up during my first repair visit a month or so after delivery. They kept it for 3 days messing with the door (my other problem was very quickly and easily resolved. This was all for the door buzz). I had a loaner and was fine. Got it back and it was better, but still to this day it will buzz/rattle on a big bass hit, even at low volume (which is the only way I listen.) Alas, I don't really use the system much anyway, so it's not been something I've bothered to take it back again for.
I've got the Burmester system but experienced the same thing from the passenger door speaker...almost sounded like the speaker was blown out. I took it in and they said they couldn't find anything wrong with the speaker but put a piece of foam in the enclosure and it fixed it.
Mine does is with the base system IF I crank the volume too high (while washing it, in order to hear it from the outside with the car closed, for example)
There were plenty of threads on this, I believe...
Put your car to Bluetooth and play this on your phone
https://m.youtube.com/watch?v=M8gjsefNYpE
see what frequency it really gets it to buzz then search YouTube for that frequency tone. Play that on loop and then go to town pressing on panels and trying to see if you can put any felt tape or wedge something to keep it from rattling.
I've been able to get my cabin pretty using this technique. Good luck
On my car, it's the passenger door window switch that buzzes on bass notes. I'll replace it next time I'm at the dealer.
To the Original Poster - try touching the window switch when you hear the buzzing. See if that stops it momentarily. It may not be the speaker at all.
My car had this issue and I swore it was a Bose speaker problem or a lose wire in the door vibrating at a certain frequency. I brought it up to my SA and they immediately said they see it all the time, and would fix by replacing the window switch module. Sure enough it's fixed.
I
I
I
I
I've had several modern era Porsches. All have done this. I'm guessing Lexus puts more R and D dollars into interior fit and finish, while Porsche puts more into driving dynamics.
Platinum Sponsor
In my experience, it's typically a problem with the way the 991 doors are designed. Most auto manufacturers couple the door woofer to the plastic grille with a foam gasket. Porsche decided that the looks of the two-piece grille was worth loosing that ability. Without that gasket, we get a good amount of acoustic energy inside the plastic door panel instead of directing it through the grille.
My passenger's door window switch was replaced today. Buzzing is gone...for now.
Go to the sound function and select option. Scroll down and select "linear" and your rattling should disappear. It seems to tighten up the bass.
My .2 rattled when playing certain music with low bass. Flipped of the 3 plastic covers on the door panel, tightened 3 screws, and the rattle is almost gone. Even with the none Bose, the speakers tend to vibrate quite a lot, and there's a bunch of stuff inside that can cause a rattle. Use a plastic tool so you dont scratch the interior parts. The screws are torx, T30.
