Airbag Warning Light
Back in April I purchased a 2013 Carrara S and I've had one consistent issue with it - the airbag warning light comes on and stays on.
It's been at the dealer 3 times for this, the 1st two they reset it (and it came back on within a couple days) and the last time they replaced the control module, which kept it off for about 2 weeks.
I detailed it the other morning, and as I was backing out I realized it was on again.
I can't be 100% certain, but I believe that pushing the passenger seat all the way back is causing this. The dealer doesn't seem to believe me, but as this is now the 4th time they will be servicing this I think they may look at this now.
Anyone else ever have this issue? If so, I would love to know what the problem / solution was.
Received 5,387 Likes
Which airbag warning light, driver's or passanger?
Turns out the previous owner had the windshield replaced and it wasn't sealed properly causing a leak that has been shorting out the system. This is getting taken care of tomorrow and I'll believe that it's better once I see it.
Seems a lottle far-fetched to me. No musty smell of any type in the car, ever.
