Visual differences between C4 and C4S?
I know the back says S, but it seems this can be deleted? And it has the quad tip exhaust, is this optional on a C4?
Besides those two items, are there any other visual differences between the two models on the outside?
What about inside? Any C4 to C4S differerences?
The pics aren't accurate. The c4 non-s also has the wide body and the red band, both for 991.1 and 991.2.
Exhaust tip style, bigger brakes, red calipers. Depending on year some options might only be offered on the S.
Is the quad tip exhaust also an option on a non S?
Can you option red calipers on a non S?
When you say bigger brakes, assuming you mean the non PCCB's?
If so, how much bigger are the regular brakes on the S?
Can you order PCCB's on both the non S and S?
Thanks!
You can get the sport exhaust tips on the base which gives it the Quad exhaust look.
You can also have your calipers painted red for a price and then have the white Porsche label put on them.
Guys have done it but if you ask me, it is posing.
Are these are options from Porsche, or do you mean doing this via aftermarket/yourself?
