Burmester - supported audio codecs?
Old 01-12-2018, 09:57 PM
simba221
User
Originally Posted by Jabs1542 View Post
Unless the iPod uses a better DAC than the iPhone 6 the device is limited to its 16 bit DAC. It plays 24 bit through software conversion, but the bit stream coming out of the unit is 16 bit. Try connecting it to your home stereo DAC and watch the bit rate and clock when they sync up - you should see 16 bit, 44.1 kHz.
I have an Astell and Kern that I could play from but I really don't care enough because of the poor car cabin acoustics and the engine sound.
I have an AK 380 and cannot get it to work with the PCM in my 991.2 GTS. It connects vis Bluetooth but then doesn't work. It is not recognized by the system when connected via the USB port either.
It connects and works in my GT4 with the previous generation PCM.
Any advice on how to get the AK 380 to work?
simba221 is offline
Old 01-12-2018, 10:04 PM
simba221
User
Default Connection problems with AK 380 in 981.2 GTS
I cannot play music from my Astell & Kern 380 via Bluetooth or connected via USB in my 991.2 GTS. Any advice?
It worked via Bluetooth with the previous gen PCM in my GT4.
simba221 is offline
Old 01-15-2018, 10:10 PM
ace37
ace37's Avatar
I play FLAC on my 991.2 via SD card, never had an issue with it.
ace37 is offline
Old 01-15-2018, 11:37 PM
simba221
User
Thanks. I'll try the same via SD card and see if that works.
simba221 is offline
Old 01-17-2018, 11:26 PM
TerryC4S
User
TerryC4S's Avatar
I connect my iPad or iPhone 7 with USB3 camera adaptor to Audioquest Dragonfly Red and then use an aux cable from AQ to aux in. I can play ALAC from the iPad/iPhone as well as stream MQA from TIDAL.
TerryC4S is offline
Quick Reply: Burmester - supported audio codecs?
Contact Us - About Us - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
